Results 1 to 10 of 13
Like Tree2Likes
Thread: Igo Primo Auto Detecting GPS
    AlanDogg is offline Lance Corporal
    Hi Folks,
    I have just installed a new GPS system into my car and originally had iGo8 in and working. I installed Igo Primo and everything is working apart from Fixing to a sat
    I get the following "AUTO DETECTING GPS"
    I added the following line to my sys file but still not detecting GPS?
    [gps]
    port=2
    baud=9600
    The system im running Igo Primo runs WinCE (Device Below)
    XTRONS D4303G 4.3" Car DVD GPS Player IPod Bluetooth | eBay UK
    YouTube - ‪XTRONS D4303G‬‏
    959
    Re: Igo Primo Auto Detecting GPS
    Thanks bud Sorted. Port setting for others using this device below
    [gps]
    port=3
    baud=9600
    jmdesai likes this.
  4. The Following User Says Thank You to AlanDogg For This Useful Post:
    paulderbybloke is offline Private
    May 2011
    try deleting your "save" folder...worked for me, as this stores info regarding GPS setup
    959
    Quote Originally Posted by AlanDogg View Post
    [gps]
    port=3
    baud=9600
    Your welcome! Always glad to help.
    Oct 2011
    How do you change the port settings?
    bazzle is offline Lieutenant
    Melb Oz
    347
    32
    That code 3 posts above is in the sys.txt file found in the top level directory of iGO.
    Open and edit with Notepad etc.
    Back up the old files 1st.
    Bazzle
    Oct 2011
    Thank you for your reply. But I don't have sys.txt, I just have sys
  10. #9
    Oct 2011
    all i find in the sys file is :
    [device]
    type="Generic GPS"
    [power]
    powermgm_state="1"
    [Main]
    ShowExit=1
    [interface]
    show_exit=1
    extra_settings=1
    resolution_dir="800_480"
    ;vga=0
    [3d_config]
    disable_roadsign_navigation_mode=1
    rotated_roadsigns=1
    show_guidance_arrows=1
    show_guidance_strip=1
    [sound]
    csv_voice_enabled=1
    use_method=1
    queue_length=200
    sound_volume=255
    voice_volume=255
    mute_os_key=1
    ding=0
    [route]
    correctness=90
    [warning]
    speedcam_enabled=1 ;(0)
    speedcam_visualtype=1 ;(1)
    speedcam_soundtype=1 ;(1) 1=warn if overspeed 2=approach
    speedcam_soundtype_4=2 ;
    speedcam_warning=1 ;(0)
    ;speedcam_check_frc=1
    speak_tts_only=1
    speedwarn_alt_builtup_based=1 ;(0)
    speedwarn_alt_limit=1 ;(0)
    speedwarn_alt_tolerance=110 ;(100)
    speedwarn_alt_toltype=1 ;(0) alternative tolerance type
    speedwarn_tolerance=110 ;(100)
    speedwarn_toltype=1 ;(0) absolute or percentage
    [debug]
    skip_eula=1
    enable_roadshadow=1
    loop_sim=1
    sound_q_length=200
    reserve_memory=1835008
    cache=262144
    [map]
    auto_nightmode=1
    map_mode="3D"
    [tts]
    tts_buffer=131072
    announce_exit_directions=1
    tts_logics=3
    priority="HIGH"
    always_say_road_names=3
    announce_street_name=1
    skip_exit_numbers=2
    filozof likes this.
  11. #10
    Melb Oz
    347
    32
    Add in the lines above and save.
    sys or sys.txt afaik the same. Depends on how your pc sees file names.
    Bazzle
