Results 1 to 10 of 19
Like Tree2Likes
Thread: IGo For HTC Sensation? with qHD (540 X 960) resolution .. Help Plz
    Hi all..
    Installed 2 versions wich didint work...
    Can any one guide me to the Right working link? right version + Map
    What i know is that Only My way works for android ??? True?
    kilroy's Avatar
    kilroy is offline Lieutenant
    Jun 2011
    440
    19
    Re: IGo For HTC Sensation? with qHD (540 X 960) resolution .. Help Plz
    Quote Originally Posted by 3kgt View Post
    Hi all..
    I have same problem. If you use the 800x480 it does not work. It give only a partial screen
    bazzle is offline Lieutenant
    Melb Oz
    347
    32
    Quote Originally Posted by kilroy View Post
    Looks like you are on the way.
    What are your Screen settings in sys.txt
    Below for 800x480
    [interface]
    vga=0
    skin="ui_igo8"
    resolution_dir="800_480"
    [rawdisplay]
    class="landscape"
    highres=0
    screen_x=800
    screen_y=480
    Also you need to ensure ui_igo8 in data.zip has your resolution included etc.
    Also when you make changes rename or delete your Save directory so iGO makes a new one.
    Bazzle
    kilroy's Avatar
    Jun 2011
    440
    19
    Quote Originally Posted by bazzle View Post
    Below for 800x480
    [interface]
    vga=0
    skin="ui_igo8"
    [rawdisplay]
    class="landscape"
    highres=0
    screen_x=800
    screen_y=480
    Bazzle
    Thank you for your quick reply. I am a newbee to iGO and Android. Where would I find the sys.txt?
    Sorry for the dumb question.
    Melb Oz
    347
    32
    In the Root directory
    Bazzle
    Jun 2011
    I tried to create sys.txt in root.
    Screen is still in 800x480IGo For HTC Sensation? with qHD (540 X 960) resolution .. Help Plz-prt-screen.jpg
    Well! I have manged to install Sygic and Copilot .. and they work..
    But still not Igo!
    Melb Oz
    347
    32
    What does your sys.txt say?
    Does ui_igo8 in Data.zip have your resolution?
    Bazzle
    Bazzle
    To be honest im not sure if the data.zip have mine?
    Wich version/link should i download!? that have my resoultion!
    IM at work now, i will tell u later what the sys.txt says.
    Thanks for the tips
    Melb Oz
    347
    32
    Open Data.zip with win rar, winzip etc.
    There is a uixx file ther. Click on it. You can then see res.
    Bazzle
  1. 29th March 2012, 18:49
  2. 27th February 2012, 18:22
  3. Qhd
    Refback This thread
    28th January 2012, 20:45
  4. 27th December 2011, 06:03
  5. 25th December 2011, 10:14
  6. 10th December 2011, 22:31
  7. 4th December 2011, 16:23
  8. 17th November 2011, 19:59
  9. 25th October 2011, 19:26
  10. 22nd October 2011, 22:45
  11. 26th September 2011, 20:40
  12. 5th September 2011, 13:11
  13. 22nd August 2011, 21:07
  14. 13th August 2011, 09:59
  15. 31st July 2011, 21:26
  16. 29th July 2011, 19:44
  17. 29th July 2011, 10:18
  18. 28th July 2011, 23:43
  19. 15th July 2011, 13:50
  20. 3rd July 2011, 17:43
  21. Igo
    Refback This thread
    30th June 2011, 00:53
  22. 24th June 2011, 13:12
