Results 1 to 7 of 7
Thread: Navigation iGO My way Europe v1.3.1
    macosxapp is offline Master Sergeant
    136
    Category: Navigation
    Feb 11, 2011
    Version: 1.3.10
    Price: $18.99
    Seller: NNG Global Services Kft.
    Copyright: 2011 NNG Ltd.
    Language:English, Finnish, French, German, ItalianRated 4+
    REQUIREMENTS: Compatible with iPhone, iPod touch, and iPad. Requires iOS 3.0 or later
    iGO My way (TM) is powered by the same navigation engine which is built on years of experience and runs on tens of millions of GPS navigation devices all around the world.
    This is Your World. It"s up to you how You want explore it, find out it"s secrets or just to put it very simply: to get where you want to be. Our task is, to give you the perfect tool for that.
    iGO My way (TM) for the iPhone offers a trendy and entertaining navigation solution at your hands. The software can be easily learned even by first-time users, who have never tried GPS navigation before.
    You can keep your maps up to date simply by updating the application—for FREE. The maps are part of the application, so navigation doesn"t depend on cellular network coverage. NO ROAMING FEES, no surprises. It simply works everywhere.
    FEATURES
    ==NAVIGATE SEAMLESSLY==
    - Fast, short, economical and easy-to-follow routes
    - Navigating to iPhone contacts
    - Supporting multi-point-route
    - POI searching along the route
    - Map browsing/exploration
    - Automatic route recalculation
    - Tunnel Mode
    ==HAVE FUN WHILE ON THE ROAD==
    - Controlling Music Playback
    - 3D landmarks of famous buildings
    - “Vehimarkers” (selectable 3D car models)
    ==WHAT"S MORE?==
    - Smart History
    - Unlimited number of Favorites
    - Lane assistance and realistic signposts
    - Calling POIs
    - “Where am I?” function for emergency situations
    - Enhanced pedestrian navigation
    - Speed warning
    NEW FEATURES
    - Help us improve the application by gathering anonymous statistics about software usage
    - Send feedback to the developers
    - Ask a question from the developers
    - Share a location with your friends (to find this option create a new route and then select More Options/Share)
    HOW IT WORKS
    Select your destination — either by searching for an address, a place of interest, or by picking a spot on the map. Our Smart Keyboard and Smart Search make it easy.
    iGO My way calculates the route to your chosen destination and displays a map overview along with the most important information, such as distance to travel and estimated travel time. Just tap „Go!” and iGO My way guides you to your destination with clear voice guidance and a smoothly moving 3D map.
    Choose from fast, short, economical or "easy-to-follow" route variants, compare the various route alternatives visually on the map, and pick the one you prefer. You can also avoid freeways, ferries, unpaved roads, and toll roads.
    INSTALLATION AND SETUP
    Application is compatible with iPhone handsets only. Due to the size of the package, we recommend purchasing and downloading the application using iTunes.
    Note: Continued use of GPS running in the background can dramatically decrease battery life. Background navigation has to be turned on, you can do this under "Settings / Advanced settings".
    http://www.filesonic.com/folder/3938601
    tanjj is offline Sergeant
    49
    28
    Re: Navigation iGO My way Europe v1.3.1
    no file! Please upload it to megaupload,thanks!
    ibo3x's Avatar
    ibo3x is offline Moderator
    Jan 2011
    Germany
    611
    62
    Jun 2011
    Quote Originally Posted by macosxapp View Post
    Feb 11, 2011
    Version: 1.3.10
    Price: $18.99
    FEATURES
    - Tunnel Mode
    ==WHAT"S MORE?==
    - Smart History
    - Calling POIs
    - Speed warning
    NEW FEATURES
    HOW IT WORKS
    SORRY .. Not file -- error 9001
    yosarian is offline Corporal
    26
    36
    inside is version 1.2.2 what a mess !!!!
    Androidzone is offline Private
    Jun 2011
    New mirrors here for 1.3.1 version!
    Fafik is offline Lance Corporal
    May 2011
    16
    2Androidzone
    1.2.2
  1. 10th August 2011, 18:36
  2. 10th August 2011, 04:58
