no answer?!!!!!!!!!!!
Did you try this?
To have Igo 8.3.1 go straight to map on startup
Open DATA.ZIP
Browse to: ui_igo8/common/ui/start.ui
Open file start.ui with notepad
find phrase: else_run 'run sc_GoToStartState'
replace it with: else_run 'STATE st_NavigateMap'
save file.
