Sure there is a NAVTEQ version
Australia83 NT 2012.Q3 Full content
Enjoy
ME
Like this post? Click the "Thanks" button below
Hi
Just wondering if there are other types of maps for Australia. I have the Whereis 19 maps. Are there NavTeq or TomTom maps for iGo Primo for Australia? Sorry for the ignorance. Would be happy if someone could explain....
Enjoy
ME
is there also a new map of new zealand from navteq? :-)
Sure there is a new NAVTEQ version
New Zealand83 NT 2012.Q3
Creadits to DVEVED
Enjoy
ME
Sorry for bugging!
I downloaded the folder. Do I put the files in it together in the content folder of the SD card? Or do they go in the folder structure already on it? I see files with some of the same extensions but some extensions on the one I downloaded from you are not there on the current maps (19.3 for Australia). How do I switch from my current Whereis maps to Navteq? Can it be done on the fly if I copy both sets of maps?
I'm not sure that you can mix both maps in same folder and how it will behave.
Here is where you should put the files:
--> the directory *\content\building\
3dl/3dc --> 3D view Landmarks/Building
petrol.3dl - 3D view of Petrol stations
--> the directory *\content\dem\
dem --> Landscape view
--> the directory *\content\histspeed\
hsp --> Smart route, allows to avoid traffic on certain hours
--> the directory *\content\map\
fbl --> Maps
fda --> Driver Alerts
fpa --> Adress points (house numbers)
ftr --> Truck Info
hnr --> Programmed long routing (international)
fjv --> Junction view
fsp --> Speed profile for a given road for smart routes
--> the directory *\content\phoneme\
phr/ph --> Pronouncing local names (for TTS)
--> the directory *\content\poi\
poi --> Points of Interest
Some of the special files will work with IGO8 and some with Primo.
Enjoy
ME
can someone help me i have a navigo sat nav running igo primo i have tried downloading maps for australia but when i select the country it only says australian capital territory any ideas i need a map of perth area?
