Results 1 to 10 of 12
Thread: Igo Primo - GPS receiver not detected
    Oct 2011
    Hello
    I have a build-in GPS system in my car (Renault)
    It is made in Korea Model HM-7 by Hajemtech running Windows Embedded CE 6.0
    Igo 8.3 works perfectly.
    Tried to upgrade into Primo 2.0
    It works but GPS receiver is not detected (After a long while I get the message "Your GPS receiver has been turned off")
    I tried to change many settings under the GPS section in System.txt (port, baud, type) with no success.
    Any idea ??
    Re: Igo Primo - GPS receiver not detected
    delete the file sys.txt the following line and test
    [gps]
    port = "X"
    baud = "XXXX"
    igo primo can operate without
    Oct 2011
    Quote Originally Posted by spriggan View Post
    [gps]
    port = "X"
    baud = "XXXX"
    I already did that
    I started with no GPS section on my sys.txt
    Then I add the port and baud stuff. Hoping it will help.
    It did not solve the problem.
    use port splitter
    Oct 2011
    Quote Originally Posted by illuminatus View Post
    use port splitter
    What is a port splitter ? And why should it help solving the problem ?
    Is it a software ?
    If yes -how you Install it on device which has no interface (apart from having a usb port) ?
    Port splitter it's a gps utility (software) with it you can solve your problem like i did ( i had the same problem on Navigon device) but you must have an unlocked device to use it.
    Quote Originally Posted by aviklug View Post
    Hello
    Any idea ??
    there is a easy way:
    [gps]
    port=auto
    baud=auto
    Oct 2011
    Quote Originally Posted by locosta View Post
    [gps]
    port=auto
    baud=auto
    It does not help
    I get the message: "Autodetecting GPS receiver"
    And then, after a while, the same message again: "Your GPS receiver has been turned off"
    Any other ideas how to solve this problem ?
    Avi
    Aug 2012
    http://cbrk.us.to/
    66
    Thumbs up Re: Igo Primo - GPS receiver not detected
    aviklug
    try this file (sys.txt)
    you can use your original file with the restrictions
    (insert symbol ";" the same command lines)
    i have helped
    grateful
    download
    sys.txt
    Aug 2012
    http://cbrk.us.to/
    66
    companions
    procedure
    1. access the file system.ini
    1.1. primo > save > profile > 01 > systen.ini
    2. delete this entry (or something like this):
    [config]
    last_saved_system_time = "11/08/2012. | 12:34:22.000"
    [gps]
    baud = "57600"
    gpstime = "1352377159"
    last_gps_date = "08/11/2012."
    last_gps_time = "12:35:09.000"
    port = "7"
    3. restart your navigator
    3.1. this operation should be done in the open or near a window
    3.2. wait for about 2 to 5 minutes (capture signal)
    reminder
    before any operation,
    always make backup prior.
    grateful
