Thread: pls help me ,i need igo primo which can use Arabic languagel
    china
    pls help me ,i need igo primo which can use Arabic languagel,,I let Lang_Arabic_Pna.zip Add to LANG, I use the Arabic language, igo primo 8.5.11.154123 only shows half of the Arab,,
    100
    Re: pls help me ,i need igo primo which can use Arabic languagel
    did you try taking the amigo's lang file (*.gro) and convert it to zip file?
    it will work if you find arab lang file for amigo.
    if you don't womt to do it you can edit the file yourself. in the lang file there is dictionary file. you can add there what ever you need. don't unzip the lang file. double click on it.
