Have you update your data.zip and your branding.zip ? there should be a 800X400 folder inside both zip file, as well as your skin file.
I have chinese 5" GPS from EBAY with 800*480 res.
It came with working primo with run fine, but I want also IGO8 for backup installed side by side...
I put IGO 8.3.4.117940 on SD card, but the first screen - I see only part of the screen - I can choose language, but I cant see the GO button.
Your advise will be appreciated!!
The sys.txt file:
[folders]
app="SDMMC\iGO8"
[interface]
skin="ui_igo8"
screen_x=800
screen_y=480
resolution_dir="800_480"
vga=0
[rawdisplay]
highres=0
screen_x=800
screen_y=480
Deposit Files
iG0 8.3.2.xxxxx 800x480 wince 6
no map, poi or buildings
with english lang & voice
