Hello;
i downloaded RebornSkinV1.5.5_Android_960+ and RebornSkinV1.5.6_Android_960+_Stretched and used on Galaxy Nexus (1280x720).
It doesnt stretch full screen.
how can i stretch?
Thank you.
Where to put : Speed Camera Voices to work, I dont have any camera voice
and where to put folder from these archive TTS Speed Camera Voices v1.3
Show me the corect path
Thanx
There should be a button that appears in the corner of your screen. You need to press it and select "zoom to fill". I have only tested this version on a 1280x800 screen with the lcd density set to 160. If your LCD density is set to higher than 200, you might run into problems. That is what I experienced using an android emulator. I don't have of these devices to actually test on them. If that still doesn't work, your best bet is to use the 960+ version with the black bars on the side and bottom.
For the voices, you can only have one installed. Select the one language you want to use from the pack. Then copy over the content folder for that one language and merge it with your igo content folder. In the end, the files will go into the "voice" folder.
Example: /sdcard/iGO/content/voice/TTS-Caution.zip
In order for the TTS cameras to work, you need to have an android TTS app installed in your language, like this one: https://market.android.com/details?i...ck.fin_fin_fem
Also all of these should be the set to the same language: your Android OS language, your Android TTS language, your iGO language, and your iGO TTS voice language. If those are not all the same, android and iGO can have problems.
Well this is what you are supposed to see in the corner of your screen: android-3-2-zoom-to-fill.png
You should see it even if you use the regular 960+. It is a part of Android 3.2 and above. The difference is the regular 960+ will over zoom. Normally it will over zoom to 4x the size of the screen. But I have not tried it on a device with such a high ppi. My emulator crashes after a certain point. If the regular 960+ has a zoom to fill button and if that causes it to be slightly too large for the screen and not 4x the size of the screen, please let me know and I might be able to make a special version that will work well on your device.
First of all thank you for your interest.
I tried it galaxy nexus. 1280x720 resulotion, 316ppi density and ICS.
Nor 960+ version neither 960+ stretched version I can't see these choices.
I (and the others who have galaxy nexus) will be pleased if there is a skin for nexus
(i opened a thread for ask any other skin for nexus, about 50 people viewed this thread. That looks like another people waiting for it)
Thanks again...
These two are what I am referring to:
1024x600, 1280x800, 1280x720, 1024x768, 960x640: Multiupload.com - upload your files to multiple file hosting sites! (This will not fill the screen, but it is the best you can do until Reborn 2.0 comes out.)
Stretched: Multiupload.com - upload your files to multiple file hosting sites! (Special version that might stretch to fill your screen if you have android 3.2 and above. Only confirmed to work with 1280x800 so far)
I just added the second link to the download post. Sorry I had forgotten to add it. If the stretched version does not work right away with the "zoom to fill" option, try reducing your ppi to 160. Even if you don't keep it there, please let me know how the "zoom to fill" worked with the different ppi settings.
If you try the non-stretched one, try to use the "zoom to fill" with 316ppi. Is the display 4x too large or ~1.2x too large? If it is 1.2x too large, I can make a new skin that will probably work on your device.
Hello bobroberts2;
Thanks for everything...
I tried both of them. Screen shots are here:
Screenshot_2012-01-06-10-49-45.jpgScreenshot_2012-01-06-10-49-57.jpgScreenshot_2012-01-06-10-52-18.jpgScreenshot_2012-01-06-10-52-40.jpgScreenshot_2012-01-06-10-52-48.jpg
I said before i can't see any option to set "zoom to fill" or "stretch".
My phone is not rooted. So i cant change its ppi setting or i don't know how can i change it.
So i am waiting a new skin for 1280x720.
Best regards...
Hi Bobroberts
I installed Reborn 1.5.3 960x540 on my HTC Flyer tablet running 2.3.4, res. 1024x600 upon recommendation from SantaMaria http://gpsunderground.com/forum/andr...1-800x480.html. I think it's almost perfect and just short 1 cm each side, otherwise it's performing great. I just noticed you have a newer version of Reborn
Thank you very much for your work![]()
