Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Like Tree5Likes
Thread: iGO MyWay Android Reborn Skin v1.5.5 Final! EUR+ TTS Multi-Res
  1. #21
    bobroberts2 is offline Lance Corporal
    Nov 2011
    re: iGO MyWay Android Reborn Skin v1.5.5 Final! EUR+ TTS Multi-Res
    Thanks for the updates. The screen zooming is still a little bit of a mystery to me. The documentation for android says that it is supposed to double the size of the window, but that does not seem to be true in all cases. I'm not sure why you don't even have the option of zoom, mkayik. It must be your rom. All android 3.2 and newer is supposed to have zoom to fill. I know it is frustrating to have all that unused space. I blame both iGO and google for not addressing this problem. How hard is to force a window to stretch to fill the screen, Google? And iGO, how hard is it to make your program work on devices it was never intended to run on? It's almost like iGO doesn't want us to use their software
    Hopefully the next version of iGO will fix this.
  2. #22
    mkayik is offline Private
    Nov 2011
    Quote Originally Posted by bobroberts2 View Post
    Thanks again bobroberts2. You are a helpful friend.
    I am agree with you. But we cant do anything. Anyway
    It's not problem for me. I can use 960+ skin while waiting a new version.
    Thank you and take care.
    Best regards.
  3. #23
    DarkGremlin is offline Moderator
    Mar 2011
    533
    25
    Works great on a 800x480 SG2(Epic 4G Touch).
    Thanks BobRoberts!
  4. #24
    Feb 2012
    Re: iGO MyWay Android Reborn Skin v1.5.5 Final! EUR+ TTS Multi-Res
    I have just installed this skin, it is great and I love it, I have one issue though all my mobile speed camera alerts are now been anounced as toll booths. Do you know how to correct this?
    Also do you know if you can enable tic, I am running this on a samsung galaxy s 2.
    Thank you in advance,
    Mark
  5. #25
    Nov 2011
    Hi there,
    There are multiple speedcam "formats". Your speedcam.txt is probably in an alternate format from the default one in the skin.
    I provide a way to use Primo/igo8 (regular alerts) format instead of Eur+. If you don't want to use the EUR+ speedcam alerts and want to use the regular format, copy the contents of the "Regular_Alerts" folder into your iGO folder. Then attempt to manually add a speedcamera and deselect the "EUR+" option so that it shows "Reg". The contents of the "Regular_Alerts" folder change the icons that appear on the map. The "EUR+" button changes the rest of the icons and changes the TTS alerts to follow the regular alert system.
    What is "tic"?
  6. #26
    Feb 2012
    Thank you the table makes perfect sense so if I try to find a speed cam.txt which is in the eur+ format the that will work. As for tic the spellcheck change it from tmc to tic, it was meant to be tmc.
    Thank you again for your advice.
  7. #27
    Nov 2011
    Yeah, I don't think this version support tmc, or at least no one has figured it out yet. The skin itself has the default icons and menus for tmc, but they don''t appear until a tmc device is detected.
  8. #28
    Feb 2012
    dammam
    Thankssssssssssssss
  9. #29
    CCollado is offline Private
    Mar 2012
    Quote Originally Posted by DarkGremlin View Post
    Thanx to bobroberts2
    This skin (aka My Amigo Skin) was originally made for Amigo on WM and was ported over to the Android platform. Credit goes to freddysam and mmarz for starting this skin. It is designed to look like the original iGO skin by default. Turn on the desired advanced features through the settings menu.
    Updated to v1.5.5 to fix a minor error:
    320x240: http://www.multiupload.com/Z7SD3X1CTT
    400x240: http://www.multiupload.com/KT631OH037
    480x320: http://www.multiupload.com/9T3M9ED3MK
    800x480: http://www.multiupload.com/TGOGN1EA8C
    854x480: http://www.multiupload.com/0SZSSYDR44
    960x540: http://www.multiupload.com/ZVPCHGT7JB
    1024x600, 1280x800, 1280x720, 1024x768, 960x640:
    http://www.multiupload.com/N558RCU7P3 (This will not fill the screen, but it is the best you can do until Reborn 2.0 comes out.)
    Stretched: http://www.multiupload.com/DRO26LA0K0 (Special version that might stretch to fill your screen if you have android 3.2 and above. Only confirmed to work with 1280x800 so far)
    PW: bobroberts
    The skin itself contains multiple sets of POI icons. You can change the icons individually by going to "More..." -> "Manage Places", or you can change the icons in bulk by using one of these branding.gro files:
    Branding 2: Multiupload.com - upload your files to multiple file hosting sites!
    Branding 3: Multiupload.com - upload your files to multiple file hosting sites!
    If you want to revert back to the default POI icon set (Branding 1), use the branding.gro included with the skin or simply delete the branding.gro that you are using.
    To install:
    Replace your original data.gro with the included one and merge the iGO folder with the one on your SD card. If you are using iGO Thin, then you don't need root and all the files can be accessed on your SD card. If you are using regular iGO, you will need to replace the data.gro located here: /data/data/com.navngo.igo.javaclient/ as well as the audio folder which will require root.
    Change Log: Multiupload.com - upload your files to multiple file hosting sites!
    Make signposts solid: Multiupload.com - upload your files to multiple file hosting sites!
    For Non-English Users
    Speed Camera Voices: Multiupload.com - upload your files to multiple file hosting sites!
    TTS Speed Camera Voices v1.3: Multiupload.com - upload your files to multiple file hosting sites!
    (Includes 28 languages!)
    Toolkit to edit the skin: Multiupload.com - upload your files to multiple file hosting sites!
    GROconverter turns the data.gro into a zip.
    BMPconverter uncompresses the BMP images for editing.
    To use the TTS features, you must have iGO My Way v8.4.3.179971 or newer.
    speedcam.txt values
    tts alerts
    How to add custom POI's using KML files:
    More info: Userdate POI & Icons file
    Example KML: Multiupload.com - upload your files to multiple file hosting sites!
    The example POI is near N45.38762 E13.00259
    Put that into the Long. & Lat, Select "Show on Map" -> "More Options" -> "Places Around Cursor"
    It will be named "Lidl"
    ummm, why is there a picture of you on this post?
  10. #30
    Mar 2011
    533
    25
    Not sure how and why that picture got in there...wasn't in the original post....
