Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Like Tree5Likes
Thread: iGO MyWay Android Reborn Skin v1.5.5 Final! EUR+ TTS Multi-Res
    DarkGremlin is offline Moderator
    Mar 2011
    533
    25
    Thumbs up iGO MyWay Android Reborn Skin v1.5.5 Final! EUR+ TTS Multi-Res
    Thanx to bobroberts2
    This skin (aka My Amigo Skin) was originally made for Amigo on WM and was ported over to the Android platform. Credit goes to freddysam and mmarz for starting this skin. It is designed to look like the original iGO skin by default. Turn on the desired advanced features through the settings menu.
    Updated to v1.5.5 to fix a minor error:
    320x240: http://www.multiupload.com/Z7SD3X1CTT
    400x240: http://www.multiupload.com/KT631OH037
    480x320: http://www.multiupload.com/9T3M9ED3MK
    800x480: http://www.multiupload.com/TGOGN1EA8C
    854x480: http://www.multiupload.com/0SZSSYDR44
    960x540: http://www.multiupload.com/ZVPCHGT7JB
    1024x600, 1280x800, 1280x720, 1024x768, 960x640:
    http://www.multiupload.com/N558RCU7P3 (This will not fill the screen, but it is the best you can do until Reborn 2.0 comes out.)
    Stretched: http://www.multiupload.com/DRO26LA0K0 (Special version that might stretch to fill your screen if you have android 3.2 and above. Only confirmed to work with 1280x800 so far)
    PW: bobroberts
    The skin itself contains multiple sets of POI icons. You can change the icons individually by going to "More..." -> "Manage Places", or you can change the icons in bulk by using one of these branding.gro files:
    Branding 2: Multiupload.com - upload your files to multiple file hosting sites!
    Branding 3: Multiupload.com - upload your files to multiple file hosting sites!
    If you want to revert back to the default POI icon set (Branding 1), use the branding.gro included with the skin or simply delete the branding.gro that you are using.
    To install:
    Replace your original data.gro with the included one and merge the iGO folder with the one on your SD card. If you are using iGO Thin, then you don't need root and all the files can be accessed on your SD card. If you are using regular iGO, you will need to replace the data.gro located here: /data/data/com.navngo.igo.javaclient/ as well as the audio folder which will require root.
    Change Log: Multiupload.com - upload your files to multiple file hosting sites!
    Make signposts solid: Multiupload.com - upload your files to multiple file hosting sites!
    For Non-English Users
    Speed Camera Voices: Multiupload.com - upload your files to multiple file hosting sites!
    TTS Speed Camera Voices v1.3: Multiupload.com - upload your files to multiple file hosting sites!
    (Includes 28 languages!)
    Toolkit to edit the skin: Multiupload.com - upload your files to multiple file hosting sites!
    GROconverter turns the data.gro into a zip.
    BMPconverter uncompresses the BMP images for editing.
    To use the TTS features, you must have iGO My Way v8.4.3.179971 or newer.
    speedcam.txt values
    tts alerts
    How to add custom POI's using KML files:
    Quote Originally Posted by kusuriuri
    a) Copy the BMP file you want to use to iGO/content/userdata/usericon
    b) Massage your KML as follows--just below the header telling what version of Google Earth KML add the following:
    <Document>
    <name>(the name of your POI here as you want it to appear in iGO)</name>
    <metadata><igoicon><filename>content\userdata\user icon\(poi BMP name.bmp)</filename></igoicon></metadata>
    (it is "usericon" with no space, xda adds a space for some reason after I post)
    c) Add your KML files to /iGO/content/userdata/poi
    UPOI Editor will do this automagically, and for large sets of POIs at that--and it exports cleanly to KML that iGO will take natively, so I think we're fixed
    Suggestions for icons--you'll need to do them in BMP format, 40x40 would appear to be the practical limit if the big "icon stacks" out of a standard branding.gro or data.gro file are anything to go by, though a lot of these are 32x32. Nmollet's PNG icons for Google Maps converted to BMP (Map Icons Collection | Google Maps Icons, Map Markers, Free POI Icons, GIS Symbols) work quite well in iGO once KML files have the appropriate headers, and these are just straight BMP conversions from a 32x37 PNG file.
    More info: Userdate POI & Icons file
    Example KML: Multiupload.com - upload your files to multiple file hosting sites!
    The example POI is near N45.38762 E13.00259
    Put that into the Long. & Lat, Select "Show on Map" -> "More Options" -> "Places Around Cursor"
    It will be named "Lidl"
  2. The Following 7 Users Say Thank You to DarkGremlin For This Useful Post:
    bobroberts2 is offline Lance Corporal
    Nov 2011
    re: iGO MyWay Android Reborn Skin v1.5.5 Final! EUR+ TTS Multi-Res
    Thank you to DarkGremlin for posting this. If you have any questions about the skin, I'm here to answer them. Enjoy!
    lightman33 is offline Corporal
    15
    26
    Thanks work fine on my galaxy tab p7510
    Nov 2011
    moshef and mn12we45 like this.
  6. The Following User Says Thank You to bobroberts2 For This Useful Post:
  7. #5
    Nov 2011
    djole84 and blanktruth like this.
  8. The Following 2 Users Say Thank You to bobroberts2 For This Useful Post:
  9. #6
    Dec 2010
    Thank you for the files. But may I ask what the RAR password is?
  10. #7
    atomantmk is offline Staff Sergeant
    Apr 2011
    Macedonia
    94
    49
    Quote Originally Posted by blanktruth View Post
    bobroberts
  11. #8
    Nov 2011
    Sorry about that. I added the password. You should also re-download the skin as I accidentally uploaded the wrong version originally. The current links are correct.
  12. #9
    15
    26
    you are right, installed 102x600 version
    can see any difference with 960x540 version on my samsung P7510
    thanks for your job
  13. #10
    15
    26
    thanks for your job
