tap the bottom left corner box
cheers
Baz
Sorry if this has been asked before, but I can't find any specific threads on it.
On previous versions of the software there has been a mute sound icon which was soooo useful. I can not find one in primo 2. I know there are way to mute the sound, but non of them are readily accessible whilst driving, simply touching a mute button is so easy.
Any help, hints, ideas much appreciated.
cheers
Baz
if you are using dimka skin, then tapping the lower left button will mute the sound
Just wondering if adding this to the sys.txt will add a mute button?
[sound]
mute=1
No, it will not
