Thread: Tweaks to preserve memory on IGO primo 2.1
    Hi Community,
    Are there any ways to preserve memory. I am using Primo 2.1 with pretty much the default config on my WindowsCE 4.2 with 64MB Ram.
    The problem is that I am getting a "low memory" crash sometimes.
    So can I tweak the INI file to use less of something or turn off something in the settings which is not really important.
    Thanks!
    Peter
    kamoteka is offline Master Sergeant
    147
    Re: Tweaks to preserve memory on IGO primo 2.1
    Remove dems and buildings. Use non-TTS voice.
    duffer is offline Captain
    Jun 2011
    660
    26
    Primo is NOT good for WinCE 4.2. Use IGO8 instead.
    801
    160
    Quote Originally Posted by kamoteka View Post
    Quote Originally Posted by duffer View Post
    Both of you have right.
    If using Primo in low memory and wince 4.2, you have to deleted all and only use the map and normal voice, but you still have to run in problems with memory.
    Like "duffer" say.... use iGO8 and maybe Primo 1.2, but the best option for you are iGO8
    Have fun
    Hey Guys, Thanks for your help.
    I will test and see if there are any improvements.
    I used IGO 8.5 on this device but suddenly the voice guidance stopped working.
    Even my backup (fresh old copy) couldn't bring the voice back. It was only saying (please turn back... and Your over speed limit).
    So I installed Primo and voila ... voice is back. Weird.
    Cheers!
    Jun 2011
    660
    26
    Quote Originally Posted by blazeblade View Post
    Cheers!
    And of course you deleted the save folder from the backup before you installed it to the new device?
