Results 1 to 8 of 8
Thread: Arrow removal for igo8
    Beartraxx33's Avatar
    Beartraxx33 is offline Sergeant First Class
    Ottawa, Canada
    117
    19
    Question Arrow removal for igo8
    has anyone figured out how to remove or make smaller the arrow in igo. i am using gurjon skin but arrow sticks out of the vehicle sides
    any help is apreciated
  2. The Following 2 Users Say Thank You to Beartraxx33 For This Useful Post:
    rasek's Avatar
    rasek is offline Private
    Perth, Australia
    Thumbs up Re: Arrow removal for igo8
    To Remove Arrow below Car Icon (when using Skin)
    Add this to sys.txt:
    [map]
    3d_scale_carmodel=1
    3dcarsizemin=1800
    3dcarsizemax=2400
    3dcarsizemul=1200
    Ottawa, Canada
    117
    19
    Quote Originally Posted by rasek View Post
    [map]
    3d_scale_carmodel=1
    3dcarsizemin=1800
    3dcarsizemax=2400
    3dcarsizemul=1200
    Works like a charm, thanks rasek...
    rasek, thanks for this solution !
    nca
    nca is offline
    I'm using Dimka skin and the arrow is too large in 2D. In 3D i have managed to shrink it but I did not figure out how to shrink it in 2D. Please, can anyone help me!
    LE: Nevermind about it! I did it!
    I've tested it on my iGO8 and it works well. All you have to do is to add these lines in your sys.txt file:
    [2d]
    mincarsize=50
    mincarsize_zoomlevel=2000
    maxcarsize=100
    maxcarsize_zoomlevel=200
    davenetv is offline Corporal
    NE Eng
    26
    29
    thanks can see how to make arrow smaller but i would like it the same size
    as in 2D can you help AND can you change the colour of the arrow
    iGO8 itis a gurjon skin
    Thanks Dave
    Good day all,
    Fisrtly, thanks for a great forum!!!! I have iGO8.3 on an HTC TyTNII. I have tried all the settings mentioned here to remove/make my arrow smaller, but they just do not work. Its almost like the sys.txt is not even being read. I am using dimka by wertVRV/Megaduck v 1.1.39 skin. Is there ANY other setting available to fix the too large arrow from sticking out under the car? (not the 3dcars, just the normal kimyaci 365 car pack from the Dimka website). Any help would be appreciated.
    Thanking you for your time and assistance,
    markanthony
    Yurbuh Tuggly is offline Corporal
    16
    Quote Originally Posted by markanthony View Post
    Good day all,
    You may be editing the wrong sys.txt--depending on how Igo is installed, you may have two; one on your removable storage card, and one on the devices internal memory/storage (where the Igo executable may also be). If this is the case, the sys.txt on your card is ignored, and the internal one is used. Try editing that one.
