Results 1 to 8 of 8
Thread: Skin problem - Igo Primo 1.2.
    omerta1988 is offline Lance Corporal
    I've downloaded some skins for Primo 1.2, and I create folder "skin" in content and put them there. When I start navigation I cant find where I can activate that skins?
    I tried to extract those files but there are some errors.
    Regards!
    joking742's Avatar
    67
    Re: Skin problem - Igo Primo 1.2.
    No don't extract...skins should stay in .zip format, just place in (create if needed) content/skin.
    Select when running...settings display (select day/night) exit and restart for effective.
    Quote Originally Posted by joking742 View Post
    I tried but everything seems to be the same like before.
    959
    Hoping to make this a little clearer, select More/Settings/Display/;
    The screen will look like this:
    Click on Day Skin Theme and the screen will look something like this:
    Select the skin you want to use and press the back button.
    Now select Night Skin Theme and choose the skin you wish to use.
    Press the Back button, and then press the Restart Button. When Primo restarts, you should have the selected skin functioning.
    22merlin is offline Lance Corporal
    I too have a problem - in that the downloaded skins, placed in the skin folder, do not show up when I navigate through as you have detailed.
    I must be doing something wrong... I just can't figure out what. Just for info - I downloaded the zip file and put the whole file into the Skin folder. Is this correct ?
    Any help much appreciated.
    Crocodile Gunn D is offline Corporal
    Quote Originally Posted by 22merlin View Post
    It's possible the data / branding files don't contain the relavent file for your resolution. Right click each of these file and then open ui_igo8 or ui_igo8_da to see whats in them.
    Apr 2011
    Primo skins Howto
    Can someone please help, new-be here how do I or what do i do to change skins in primo 1.2 , the right skins where to put them and how to change them, please be specific.
    Mar 2011
    Question Re: Primo skins Howto
    Hello friends, I'm using 9.2.1.178658 primo, I installed the on WinMo 800x480.
    Gurjon skin which are suitable for use in order to display raster map option menu.
    Thank you
  1. 1st November 2011, 10:56
  2. 12th June 2011, 22:04
