I have created the .txt file and saved in content/speedcam folder, now how do i reboot? Sorry to be a pain, this is all very new to me
I have tried turning the GPS off, but it dont seem to be adding the file you say it should, I have double checked everything is in the right folders and still no cams. Any ideas??
Yes IGO 8, Zenec NA-2000N Nav system
It's as simple as this;
1) download the archive
2) extract the archive to produce the .txt file
3) move the .txt file to /content/speedcam
4) restart igo and it should convert the txt file to a spdb file
If this doesn't work delete all files in the content/speedcam folder except for the speedcantext.txt file. Rename the speedcamtext.txt file to speedcam.txt, and restart IGO.
If that doesn't work, I'm baffled?
Anyone have a UK only speedcam file, I have the full Europe version but only running UK maps.
Any help appreciated.
file is no more available, can you please create a new link ?
