first of all, thanks for the speedcams. I've got a little problem with them.
I've put the txt file in the correct folder and rebooted.
Igo makes the database file, but it is 0 kb. also it makes only the spud file while other posts on the forum and google often mention a SPDB file which Igo doesn't create.
Anyone an idea ?
thanks!
btw i use igo 8.4.3 on android.
45Likes
LinkBack URL
About LinkBacks
