Thread: POI settings keep resetting
    Hi, im running igo on a mytouch g4 on a link I found here. It works great, the only problem im having is the poi settings keep resetting everytime I try to change them. Anyone else having this problem? Thanks, Caissie
    Re: POI settings keep resetting
    I deleted the renamed the.poi file just to prohibit access temporarily and that removes all the icons, but of course won't allow poi searches, but the screen is so cluttered with icons, you cant see the map. Also, tried replacing the copy.db file with one I had on a from amigo where I had save d the settings as off, but no luck. Im no pro, just trying to learn. Any input would be appreciated. Thanks, Caissie
    Running v.8.4.2.139242
    Android 2.2
    Skot53 is offline Lance Corporal
    Feb 2011
    Estados Unidos de América
    I had that problem when I tried to select a couple POI in each category. Try selecting less POI, or perhaps try moving the folders you want to "My POI".
  1. 6th May 2011, 17:45
