Results 1 to 10 of 15
Thread: Igo Primo speedcam problem
    Alex1986 is offline Corporal
    23
    Hello everybody, i have a small problem with my Igo.
    I install this version yesterday Igo Primo 2011(february) 9.2.1.178658 and also i downloaded speedcam text files into speedcam folder. when i browse the map, or create a simulated route i can see the speedcam icons as poi, but there is no camera warning sign or sound. Can you please help me?
    I am using chinese gps 800x480HD with 128MB rab, 500Mhz processor etc.
    3,134
    216
    Re: Igo Primo speedcam problem
    Quote Originally Posted by Alex1986 View Post
    Put the kml file in content/userdata/poi
    If the directory does not exist - create it
    23
    But the speedcam that i have is TXT file. Should i re-download a kml version?
    I would like to use this txt because there are a lot cameras mixed inside.
    Yurbuh Tuggly is offline Corporal
    16
    If your only problem is with the sound warnings, then no, you don't have to do any of that--a speedcam.txt file is just fine for iGo/Primo to create the proper database. Check to be sure that you have the warnings enabled in the Sound and Warnings section of Settings (and that you accepted the 'legal' disclaimer). If these warnings are already enabled...do you get all other sounds and voices OK?
    23
    Quote Originally Posted by Yurbuh Tuggly View Post
    In the sound menu i have these options : Speed warning settings ; alert point settings and warning sign alerts. There is no speedcam settings as it suppose to.
    I also can hear saying go 3.2km bla bla when i do a simulate route.
    3,134
    216
    speedcam and kml files are different.
    Text points to the co-ordinates of the speedcam.
    KML shows the popup icon on the map or route
    23
    Well that is what i am saying, i downloaded a txt file with cameras, and i copy it into speedcam folder. Now when i browse map, or create simulated route, i can see the cameras as poi small icons, but when i get close to it via simulated route, there is no warning message or sound.
    16
    Go back to Australia for your answer.
    You do NOT need to mess about with KML files--this has absolutely nothing to do with the sound or icon warnings. Both are built into Primo. SIMULATION is your problem right now. There are no speedcams or warnings (sound or otherwise) in Simulation Mode.
    AND you need to get a satellite lock at least once with the speedcam.txt file in place before you can enable the warnings for such.
    AHMHeeren is offline Sergeant
    The Netherlands
    57
    I got another issue with voice-warnings using TTS Pro in Primo 1.2.
    It seems that after I marked the different speedcam-types in TTS Pro, I get a generic warning voice (speed control) and not a differentiated one as I put into my sys.txt.
    Is there a way to get the differentiated voice-warning back when using TTS Pro ?
    R/T
    Good day: You need the TTS file and also the speedcam do not activate unless you are driving in real time. Also, remember that there is a 15 meters of so delay due to accuracy ie you may hear the alert 15 meters after passing the point of cam.
  1. 20th November 2011, 11:00
