Thread: POI HELP
    Alex1986 is offline Corporal
    23
    POI HELP
    i`ve added my custom poi into the Content\userdata\poi folder, and when i list them trough Igo Primo, all of them are with same icon. Is there anyway i can change the icon on that KML file? Thank you
  2. The Following User Says Thank You to Alex1986 For This Useful Post:
    Sukkis is offline Private
    Apr 2011
    Re: POI HELP
    Yea.. Im having the same problem!!! Is it possible to change the icon?
    23
    Re: POI HELP
    The way that i am doing it now, is i download another branding.zip file full with icons, and when i create a new poi, there are a lot of icons to choose. but only when i create poi. the custom poi`s that are in the kml file are with global icon.
    search on the forum for another branding.zip file and try like that.
    Apr 2011
    Re: POI HELP
    Quote Originally Posted by Alex1986 View Post
    Yep.. I read about that on another forum.. Have to try that way when i have enough time..
    viossboss is offline Private
    Mar 2011
    27
    Re: POI HELP
    in the menu were you tap to see the distance of poi 1km , 5km ,etc; tap the icon of the poi and if you have the proper branding zip you should see the alternative icons. for branding zip I will recommend stancy2 Good luck
