Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Help Installing Igo 8 On Chinese Gps
  1. #11
    Dec 2012
    Re: Help Installing Igo 8 On Chinese Gps
    sniper did you fix your prob ? if so can u pass info to me on how to do please thx a lot.
  2. #12
    filesupload100's Avatar
    filesupload100 is offline Master Sergeant
    Nov 2012
    140
    18
    Hi
    I have a working version of IGO 8.3.4.102680, it's working on a chinese device, WINCE6.0, 128M sdram.
    Any big changes between 102680 to 102680 or 142975?
    Should higher version (8.3.5) work on this device?
    If from your experiance it shuold work, I'll be greatfull for a link to download.
    Thank you
    ME
    1741ws likes this.
  3. #13
    koster is offline Private
    Dec 2012
    I managed to have a copy of the Igo Primo MFM Singapore/Malaysia/Brunei 2012 Map. It is meant to be installed onto Eonon D5123 which runs on Windows CE6.0. However, when I extract the map, it only has "Content" & "Licence" folders. It does not have any .exe files. Could some pl advise how to install the map onto the Eonon D5123 and would appreciate if someone can send me the link for the .exe files.
    Many thanks in advance. Cheers.
  4. #14
    3,132
    223
    You must be using Igo Primo version - not iGo 8 version.
    Just copy the contents of the maps into map folder.
    License into license folder.
    There is nothing to install. This are ready maps.
  5. #15
    Dec 2012
    I would like to know too.
  6. #16
    Jan 2013
    Hi,,, im a new user and soon i hope i will become slightly below novice user
    anyhow,, could somebody point me in the right direction as to where to download the newest version of igo maps
    i bought the gps unit on ebay a couple years ago from china,, but cant seem to update it
    think my version is igo8 ...my way?
    thank you for any help
  7. #17
    duffer is offline Lieutenant
    Jun 2011
    436
    And you are from.........?
  8. #18
    say1anonly is offline Sergeant
    Jan 2013
    39
    can some ono send igo8 links please
  9. #19
    mytheuzen's Avatar
    mytheuzen is online now Lieutenant
    Jan 2012
    395
    Quote Originally Posted by say1anonly View Post
    Look at your private messages.
  10. #20
    FENDERS is offline Private
    Jan 2013
    Hey guys, new to this forum, lots of great info. I just got my 6.2 china dvd which came with IGO on the sd micro with usa only maps. It looked corrupted in some of the directories and it would give me fatal error, cannot find language folder. Anyhow, was hoping someone could send me the links. I'm trying to get garmin working on it as well (which I have). I need North American Maps, canada and usa.
