Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
Thread: Help Installing Igo 8 On Chinese Gps
  1. #21
    mytheuzen's Avatar
    mytheuzen is offline Lieutenant
    Jan 2012
    417
    15
    Re: Help Installing Igo 8 On Chinese Gps
    Quote Originally Posted by FENDERS View Post
    Hey guys, new to this forum, lots of great info. I just got my 6.2 china dvd which came with IGO on the sd micro with usa only maps. It looked corrupted in some of the directories and it would give me fatal error, cannot find language folder. Anyhow, was hoping someone could send me the links. I'm trying to get garmin working on it as well (which I have). I need North American Maps, canada and usa.
    Check your PM.
  2. #22
    788
    151
    Quote Originally Posted by SNIPER357 View Post
    i also have a chinese system with ce6 could someone point me in the right direction for installing new maps on it
    You just download the new maps and replace it with the old ones
    New maps: HERE
    Just so simply to do
    Have fun
    Only Torrent Uploads, Faster And Safely Downloads
    Android GPS software TomTom, Sygic, iGO, Navigon
    <<PUSH>>
    iGO R3 Maps around the world
    <<PUSH>>
    TomTom Iphone All Maps Around The World
    <<PUSH>>
  3. #23
    scstormwolf is offline Private
    Jan 2013
    Hi Koster,
    Can you share the file? Been looking all over the place for IGO Primo with Singapore map.
    Quote Originally Posted by koster View Post
    I managed to have a copy of the Igo Primo MFM Singapore/Malaysia/Brunei 2012 Map. It is meant to be installed onto Eonon D5123 which runs on Windows CE6.0. However, when I extract the map, it only has "Content" & "Licence" folders. It does not have any .exe files. Could some pl advise how to install the map onto the Eonon D5123 and would appreciate if someone can send me the link for the .exe files.
    Many thanks in advance. Cheers.
  4. #24
    Jan 2013
    Quote Originally Posted by mytheuzen View Post
    Check your PM.
    hi mytheuzen,
    Can you share the link please?
  5. #25
    FENDERS is offline Private
    Jan 2013
    Thanks scorpio found them, sweet. Just wondering if there's somthing in my mscr script that is preventing my double din from saving. I keep starting tin thai or chinese and when i select the car logo it doesn't save. There was a line that shows the font in the script and it's set to chinese.ttf. If I delete the ttf will it still look for it. WHat's tha name of the english font ?.ttf
    here's my Garmin.mscr
    Errorlevel("warn")
    If(WndExists("Garmin Mobile XT"))
    Show("Garmin Mobile XT")
    Exit
    EndIf
    #Run Windows CE
    Run("\Windows\explorer.exe")
    Sleep(1500)
    #Hide Taskbar
    Run("\StorageCard\Garmin\RunGMXT\TaskbarToggle.exe ")
    Sleep(1000)
    #XCopy("\StorageCard\Garmin\GPX\*.*","\Garmin\", Yes, Yes)
    #RunWait("\StorageCard\Garmin\Apps\WM\Que.exe")
    #XCopy("\Garmin\*.*", "\StorageCard\Garmin\Save\", Yes, Yes)
    #Run Garmin Mobile XT.
    RunWait("\StorageCard\Garmin\Apps\WM\que.exe")
    Sleep(1000)
    #Show Taskbar
    #Run("\StorageCard\Garmin\RunGMXT\TaskbarToggle.ex e")
    Kill("\windows\explorer.exe")
    I've seen some other scripts but the commands are spelled slightly different, could be a difference in wince 4,5,6?
  6. #26
    Jan 2013
    I see in Gmsup tee is a line that says
    [COMMON]
    LOCAL_VER=
    It did say chinese. I removed it (chinese) and will see what happens. This is why I was asking what you would put to make the local version english.
    I have 6,2 double din WIN6.0
    RAM:128MB,CPU: R5F212A8 SOFP
  7. #27
    Jan 2013
    I just bought a new Chinese GPS device and I dont know how to install Igo on it, hopefully with russian & english interface and Israel maps
    7" TFT LCD Screen Windows CE 6.0 GPS Navigator with Bluetooth, FM (Black) EG0005B - $84.79 - Affordable Car GPS
    this is the device
  8. #28
    gps-fanboy is offline Corporal
    Feb 2013
    Hi Guys
    Could anyone of you please share a working link for iGO (for china 2DIN 800x480, 600Mhz, wince6.0). Maps of interrest is Western Europe incl. Scandinavia. Thanx alot in advance.
  9. #29
    Feb 2013
    Hi everyone,
    Complete and utter N00B right here. I bought a chinese aftermarket Navigation/GPS system for my Honda CR-V about a year ago. Here's a link to an upgraded version of the navigation i bought (looks the exact same, but appears to have newer software on it) - 8"Honda CRV DVD Player GPS Navigation 2007 11 Plug In | eBay
    Here's what i know... iGO8 is on my SD Maps Card.
    Up until about a month ago, all was working fine.
    Now for whatever reason Wince won't load IGO... when i go into the navigation setup window to map the path to the navigation software, i see the following:
    \StorageCard\NaviOne\NaviOne.exe
    In other words, the card is looking for a file that does not exist. If i rename IGO8.exe to NaviOne.exe, it doesn't work. When i try to change the path, I see [NandFlash] and it can't see any of the files in my SD card.
    Has anyone come across this issue before? Would upgrading to a newer version of iGO help resolve the issue? And if so, how on earth do i go about doing that??
    Really appreciate any help!!!
  10. #30
    0-60Motorsports is offline Lance Corporal
    May 2012
    Quote Originally Posted by scmtl View Post
    Hi everyone,
    Almost same issue here. I have the maps but not iGo. can someone tell me how to install iGO primo on my SD card for my Dynavin D99 VW model?
