Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Help Installing Igo 8 On Chinese Gps
    Aug 2011
    Question Help Installing Igo 8 On Chinese Gps
    Hi everyone...
    Could you please give me a hand, I do have a 2din chinese gps unit, currently running igomyway 6, which is no longer supported for upgrade, I would like to install a newer version or newer gps software.
    It is running wince 5.0
    the following is my sys.txt
    [interface]
    show_zoombar=1
    gxoff=1
    skin="igo_se1"
    width=240
    height=320
    vga=0
    basel="igo_se1/320_240/"
    uicommon = "igo_se1/common/"
    widescreen=1
    show_timezoneslider=1
    reset_os_timezone=1
    [gps]
    port=2
    baud=9600
    Can you please guide me how to upgrade to igo 8 or other gps software?
    I have read a lot in this forum, I am a newbie on the gps world...please help me..
    3,132
    223
    Re: Help Installing Igo 8 On Chinese Gps
    baguak is offline Private
    Oct 2012
    I have a windows ce 6 chinese car stereo. I have read every thread on this site. I can not seem to get direction on how to install and set up my GPS. I am under the impression that igo is the easiest. I need to have an .exe and north america maps. I need to know exactly what to do with the software i.e. how to set it up on my SD card. Thanks for anyone that will help!!!
    ktcmoney is offline Private
    Oct 2012
    I am having the same issue... with the EONON D5115Z (specific to 2010+ Mazda3). everything works, but can not get my position....
    I did not have sys.txt... but even found one and tried different ports (port 2 @ 9600 seemed to be the usual). no sat connectivity. argh. Sygic worked real quick, which makes me think it must be software related. anything else to check?
    Oct 2012
    Hi all.
    I have a Chinese GPS Soniq QNG400 unit running WinCE 4.2.
    I would like to bring it back to usefullness by installing iGO8, but every download link i have come across so far have been a dead end.
    Anyone have a working link to the latest release ?
    Thx
    spriggan's Avatar
    spriggan is offline Major
    772
    21
    Quote Originally Posted by vvulture View Post
    Hi all.
    Thx
    look at your PM
    danze91 is offline Private
    Oct 2012
    same! link is broken!
    can somoene pm me with new link please!
    thank you!
    Oct 2012
    thank you!
    spriggan's Avatar
    772
    21
    Quote Originally Posted by danze91 View Post
    thank you!
    look at your PM for IGO8
    Aug 2011
    i also have a chinese system with ce6 could someone point me in the right direction for installing new maps on it
