12th October 2012, 16:41
#21
Re: Help for absolute beginners
this is embarassing: you know what the problem was? this is quite silly: the GPS did not have reception because I was indoor, as soon as I went on my balcony it connected to the satellite. I think my windows block everything...
Anyhow, thank you very much, sorry for the mix up - and here are 2 other questions (hopefully not as stupid as the 1st one):
1. how can I make my Mio C520 read SDHC cards? currently it only reads standard SD cards.
2. how can I ensure that an incoming call pops on my Mio C520 screen when I am in navigation mode on iGO8? is that even possible? say I am on the road, the GPS is on, and somebody calls me. I know that the Mio is equipped with bluetooth.
Cheers
Andrei
12th October 2012, 16:59
#22
Hi andreicraciun,
I can answer to your first question.
The problem is WinCE, for adding support SDHC in WinCE 5.0:
1-Download "DLL_SDHC_WinCE50.rar" : Download DLL SDHC WinCE50 rar
2-Connect your device (PNA / PDA ..) to your PC using ActiveSync
3-Copy all DLL files in the "\ Windows \" folder of your device
4-Make a soft reset of the device
5-Turn your device. SDHC card is compatible and ready to operate.
Caution: Hard Reset clears these DLL files and restores the original DLL on the device.
The Following User Says Thank You to mytheuzen For This Useful Post:
12th October 2012, 21:12
#23
All he really needs is MioMap 3.3 to read SDHC.
The Following User Says Thank You to duffer For This Useful Post:
16th October 2012, 02:38
#24
In Sygic Drive 10 (Dynavin) touching the next maneuver icon, reiterates vocally the next maneuver. Is there a way to do such repetition in Primo 2?
26th October 2012, 09:03
#25
Hello all
I have Becker Z302 navi.
I have replaced old iGO8 folder with my clean downloaded one.
I did this on other Becker navi Z203(302 and 203 not the same model
) and works fine
On this one I got big Becker logo on startup, after that iGO8 logo and langugaes start to load on the bottom right corner and then restart and again Becker logo...and so on and so on...
Any ideas?
26th October 2012, 13:18
#26
Make sure that you have the proper entries for your device in the sys.txt.
26th October 2012, 13:43
#27
Thank you duffer for your reply.
I am in a bit of hurry now...later on I will browse a forum for tips about sys.txt because I have no ides what I need to type in there.
Or you can send me to a topic if you can or gimme some advice...if you have time....
What bugs is...on previous devise I had to do nothing! Worked like charm just like that.
Thank again...
2nd February 2013, 07:58
#28
Hi. Could anyone please post or send me a PM with a working link for iGO Primo (for a china 2DIN headunit running wince6.0, 128MB, 600Mhz). Maps of interest is wester europe. Thanx in advance
27th February 2013, 04:37
#29
Depends on what resolution your device is running..
For the other spec any kit of iGO Primo with proper resolution should work.
27th February 2013, 12:32
#30
Hi guys, I don't know why, but I still can't start a new thread so I must post it here. My problem is: I have chinese GPS with Nav n Go iGO 8 (specifically 8.3.2.93112) and WinCE 6, software works ok, but navigation process doesn't. When I'm in Configuration-GPS and press the button in right down corner to detect port and bauds automatically, it reports success (GPS receiver is connected - port 1, 38400 baud, I live in Cetral Europe if may be this a help element). When I look on realtime stats, I have around 11 red satellites, after 20 minutes nothing has changed. I was looking for a solution in crashlog and here's what I found:
------------------ Crash Log Begin -------------------
Current System time: "2013-02-26 16:19:05"
Build: 8.3.2.92992 Built @ Jun 8 2009 - 12:27:43
Memory Stats:
FreeMemory: 23 MB, 712 KB, 0 B
TotalUseableMemory: 30 MB, 424 KB, 0 B
MaxMemory: 132 MB, 0 KB, 0 B
ReservedMemory: 4 MB, 0 KB, 0 B
ActualCacheSize: 0 MB, 767 KB, 432 B
GarbageSize: 0 MB, 767 KB, 432 B
Process Name PID BaseAddr ParentPID PrioBase
WINCE_GPS.exe 0x06690006 0x00010000 0x00000000 0x00000003
Modules Name BaseAddr BaseSize
toolhelp.dll 0x40100000 0x00006000
coredll.dll 0x40010000 0x00094000
fpcrt.dll 0x421b0000 0x0000f000
oleaut32.dll 0x40590000 0x00035000
ole32.dll 0x40510000 0x0007a000
rpcrt4.dll 0x405f0000 0x00052000
lpcrt.dll 0x403e0000 0x00005000
coredll.dll.0409.mui 0x421d0000 0x00008000
Threads TID BasePrio DeltaPrio
0x066a0006 251 0
Exception: 0xc0000005
At address: 0x000161a4
Access violation reading address: 0xd2fb0001
0x000161a4 (A)
WinCE CallStack snapshot (function names unknown - map file \SDMMC\GPS\WINCE_GPS.map not found):
0x40029120 (A)
0x005fc848 (A)
0x005fc764 (A)
0x005fbbb4 (A)
0x005fbcb0 (A)
0x001a6690 (A)
0x000850c8 (A)
0x40076160 (A)
0x40057d4c (A)
0x40051f1c (A)
0x4002a3b4 (A)
0x4002a6a4 (A)
0x4005201c (A)
0x000161a4 (A)
0x00015cd4 (A)
0x00015c1c (A)
0x000141e8 (A)
0x0008507c (A)
0x000854c0 (A)
0x001a5bf8 (A)
0x001a3868 (A)
0x001a4714 (A)
0x00484488 (A)
0x00486f50 (A)
0x00486e68 (A)
0x00492ea0 (A)
0x00490340 (A)
0x001a956c (A)
0x00476638 (A)
0x000a4eac (A)
0x0009cdec (A)
0x000636d4 (A)
0x00063748 (A)
0x000a212c (A)
0x000a4f38 (A)
0x000a5f48 (A)
0x001ac860 (A)
0x001a60b0 (A)
0x001a6604 (A)
0x0061fa40 (A)
0x4003bce4 (A)
Global status:
bInFocus: 1
bMouseDown: 0
bInLogic: 0
bInRender: 0
CurrentState[128]:
GPS Pos: (0.000000,0.000000)
Camera: pos
0.000000,0.000000) rot:0 persp:0 zoom:0.000000 eng=0)
------------------- Crash Log End --------------------
Is THIS a software problem, or I need to buy an aftermarket internal antenna ? Sorry for my bad english. I WILL BE THANKFUL FOR EVERY YOUR ADVICE!
