Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Help for absolute beginners
    neleus is offline Corporal
    Feb 2012
    15
    Hi all. I have a new igo8 with Aust maps on it, I will be travelling to the USA soon and want to add those maps. Is there any chance of a guide for absolute beginners? .Everything I have tried to read assumes a level of knowledge that I do not have. I know how to get into the sd card but not how to insert anything into the right place,or what to insert. Maybe there is a guide already written somewhere?. Hope I have not broken any rules by missing something!
    Neleus
    hashima's Avatar
    hashima is offline Command Sergeant Major
    206
    47
    Re: Help for absolute beginners
    Hope this helps. Download the appropriate map, and insert the various files in the appropriate directories:
    \igo8\content\building folder: 3dc, 3dl files.
    \igo8\content\dem folder: dem files.
    \igo8\content\histspeed folder: hsp files.
    \igo8\content\map folder: fpa, hnr, ftr, fda, fbl files.
    \igo8\content\phoneme folder: phr, ph files.
    \igo8\content\poi folder: poi files.
    \igo8\content\speedcam folder: txt, spud, spdb files.
    \igo8\content\userdata\poi folder: kml files (custom poi)
    \igo8\content\voice folder: zip files
    \igo8\content\lang folder: zip files
    \igo8\content\skin folder: zip files
    If the folder don't exist, create it.
    Caution: Loading too many countries ( or too many States in the case of USA ) may severely affect performance of iGO8.
  3. The Following 2 Users Say Thank You to hashima For This Useful Post:
    Feb 2012
    15
    Thank you hashima!, will go away and work thru advice.
    neleus
    Wim66 is offline Private
    I have an Igo Primo with IGO8.5, Amigo and Gps folders. In these folders I find the maps of Thailand and south east asia.
    I am new to the IGO and my problem is that the map is in Thai. I have downloaded maps of Thailand but they remain in Thai. So I conclude to change over to english I need to set a language file but do not have any clue to do it. Researched this problem for some days already but did not find a solution.
    Can anyone give me some help? Or refer me to a place where I can get help?
    thank you in advance
    May 2012
    Quote Originally Posted by hashima View Post
    I have a question, what are all the possible types of file structure available to add if it doesn't exist?
    I have a big problem with my iGo8 Installation and is giving me trouble. I need to know the minimum file structure as well as the minimum data and files necessary to get the system back running and then also how to add files to as well as add directory structure to the flash card to expand the program as well. Thanks so much
  7. The Following User Says Thank You to aarondinkin For This Useful Post:
  8. #6
    hashima's Avatar
    206
    47
    Your problem description is not very clear. How is your installation not running properly?
  9. #7
    JEZ_222 is offline Lance Corporal
    Jul 2012
    I have igo8.exe and it just freezes after I set it to run in startup?
    Dynavin D90 Win ce 6
  10. #8
    Jul 2012
    Quote Originally Posted by JEZ_222 View Post
    ERROR LOG from Crash.doc
    ------------------ Crash Log Begin -------------------
    Current System time: "2012-07-04 07:54:30"
    Build: 8.3.5.193799 Built @ May 27 2011 - 09:58:26
    Memory Stats:
    FreeMemory: 86 MB, 336 KB, 0 B
    TotalUseableMemory: 87 MB, 532 KB, 0 B
    MaxMemory: 128 MB, 512 KB, 0 B
    ReservedMemory: 0 MB, 512 KB, 0 B
    ActualCacheSize: 0 MB, 864 KB, 368 B
    GarbageSize: 0 MB, 864 KB, 368 B
    Process Name PID BaseAddr ParentPID PrioBase
    iGO8.EXE 0x0750001e 0x00010000 0x00000000 0x00000003
    Modules Name BaseAddr BaseSize
    toolhelp.dll 0x40120000 0x00006000
    coredll.dll 0x40010000 0x00094000
    fpcrt.dll 0x400c0000 0x00012000
    oleaut32.dll 0x40520000 0x00035000
    ole32.dll 0x404a0000 0x0007a000
    rpcrt4.dll 0x40580000 0x00052000
    lpcrt.dll 0x40370000 0x00005000
    Threads TID BasePrio DeltaPrio
    0x077c0026 251 0
    0x0752001e 251 0
    Exception: 0xc0000005
    At address: 0x400630f0
    Access violation writing address: 0x10a6c000
    0x400630f0 (A)
    WinCE CallStack snapshot (function names unknown - map file \StorageCard\iGO8.map not found):
    0x40029290 (A)
    0x0063e88c (A)
    0x0063e764 (A)
    0x0063dbd8 (A)
    0x0063dcd4 (A)
    0x00166948 (A)
    0x00166914 (A)
    0x400769c0 (A)
    0x400585ac (A)
    0x4005277c (A)
    0x4002a524 (A)
    0x4002a814 (A)
    0x4005287c (A)
    0x400630f0 (A)
    0x001c1874 (A)
    0x00163e2c (A)
    0x00164884 (A)
    0x004a49ec (A)
    0x004a7b0c (A)
    0x004a7a24 (A)
    0x004b44e4 (A)
    0x004b1658 (A)
    0x00169bbc (A)
    0x0016fa7c (A)
    0x0006123c (A)
    0x00586470 (A)
    0x00039014 (A)
    0x00039088 (A)
    0x0005e3ac (A)
    0x000612c8 (A)
    0x000622b4 (A)
    0x0016d6d8 (A)
    0x001662d4 (A)
    0x001668bc (A)
    Global status:
    bInFocus: 1
    bMouseDown: 0
    bInLogic: 0
    bInRender: 0
    CurrentState[128]:
    GPS Pos: (0.000000,0.000000)
    Camera: pos0.000000,0.000000) rot:0 persp:0 zoom:0.000000 eng=0)
    ------------------- Crash Log End --------------------
    Current System time: "2012-07-04 11:22:01"
    Memory Stats:
    FreeMemory: 87 MB, 1012 KB, 0 B
    TotalUseableMemory: 89 MB, 240 KB, 0 B
    iGO8.EXE 0x07ab0006 0x00010000 0x00000000 0x00000003
    0x07b40006 251 0
    0x07ac0006 251 0
    0x400630f0 (A)
    0x40029290 (A)
    0x0063e88c (A)
    0x0063e764 (A)
    0x0063dbd8 (A)
    0x0063dcd4 (A)
    0x00166948 (A)
    0x00166914 (A)
    0x400769c0 (A)
    0x400585ac (A)
    0x4005277c (A)
    0x4002a524 (A)
    0x4002a814 (A)
    0x4005287c (A)
    0x400630f0 (A)
    0x001c1874 (A)
    0x00163e2c (A)
    0x00164884 (A)
    0x004a49ec (A)
    0x004a7b0c (A)
    0x004a7a24 (A)
    0x004b44e4 (A)
    0x004b1658 (A)
    0x00169bbc (A)
    0x0016fa7c (A)
    0x0006123c (A)
    0x00586470 (A)
    0x00039014 (A)
    0x00039088 (A)
    0x0005e3ac (A)
    0x000612c8 (A)
    0x000622b4 (A)
    0x0016d6d8 (A)
    0x001662d4 (A)
    0x001668bc (A)
    Global status:
    bInFocus: 1
    bMouseDown: 0
    bInLogic: 0
    bInRender: 0
    CurrentState[128]:
    Current System time: "2012-07-04 11:23:52"
    Memory Stats:
    FreeMemory: 88 MB, 276 KB, 0 B
    TotalUseableMemory: 89 MB, 528 KB, 0 B
    iGO8.EXE 0x07500006 0x00010000 0x00000000 0x00000003
    0x07560006 251 0
    0x07510006 251 0
    0x400630f0 (A)
    0x40029290 (A)
    0x0063e88c (A)
    0x0063e764 (A)
    0x0063dbd8 (A)
    0x0063dcd4 (A)
    0x00166948 (A)
    0x00166914 (A)
    0x400769c0 (A)
    0x400585ac (A)
    0x4005277c (A)
    0x4002a524 (A)
    0x4002a814 (A)
    0x4005287c (A)
    0x400630f0 (A)
    0x001c1874 (A)
    0x00163e2c (A)
    0x00164884 (A)
    0x004a49ec (A)
    0x004a7b0c (A)
    0x004a7a24 (A)
    0x004b44e4 (A)
    0x004b1658 (A)
    0x00169bbc (A)
    0x0016fa7c (A)
    0x0006123c (A)
    0x00586470 (A)
    0x00039014 (A)
    0x00039088 (A)
    0x0005e3ac (A)
    0x000612c8 (A)
    0x000622b4 (A)
    0x0016d6d8 (A)
    0x001662d4 (A)
    0x001668bc (A)
    Global status:
    bInFocus: 1
    bMouseDown: 0
    bInLogic: 0
    bInRender: 0
    CurrentState[128]:
    Current System time: "2012-07-04 11:45:12"
    Memory Stats:
    FreeMemory: 89 MB, 160 KB, 0 B
    TotalUseableMemory: 90 MB, 408 KB, 0 B
    iGO8.EXE 0x064d0006 0x00010000 0x00000000 0x00000003
    0x06530006 251 0
    0x064e0006 251 0
    0x400630f0 (A)
    0x40029290 (A)
    0x0063e88c (A)
    0x0063e764 (A)
    0x0063dbd8 (A)
    0x0063dcd4 (A)
    0x00166948 (A)
    0x00166914 (A)
    0x400769c0 (A)
    0x400585ac (A)
    0x4005277c (A)
    0x4002a524 (A)
    0x4002a814 (A)
    0x4005287c (A)
    0x400630f0 (A)
    0x001c1874 (A)
    0x00163e2c (A)
    0x00164884 (A)
    0x004a49ec (A)
    0x004a7b0c (A)
    0x004a7a24 (A)
    0x004b44e4 (A)
    0x004b1658 (A)
    0x00169bbc (A)
    0x0016fa7c (A)
    0x0006123c (A)
    0x00586470 (A)
    0x00039014 (A)
    0x00039088 (A)
    0x0005e3ac (A)
    0x000612c8 (A)
    0x000622b4 (A)
    0x0016d6d8 (A)
    0x001662d4 (A)
    0x001668bc (A)
    Global status:
    bInFocus: 1
    bMouseDown: 0
    bInLogic: 0
    bInRender: 0
    CurrentState[128]:
    Current System time: "2012-07-04 11:48:24"
    Memory Stats:
    FreeMemory: 88 MB, 432 KB, 0 B
    TotalUseableMemory: 89 MB, 684 KB, 0 B
    iGO8.EXE 0x07140006 0x00010000 0x00000000 0x00000003
    0x071a0006 251 0
    0x07150006 251 0
    0x400630f0 (A)
    0x40029290 (A)
    0x0063e88c (A)
    0x0063e764 (A)
    0x0063dbd8 (A)
    0x0063dcd4 (A)
    0x00166948 (A)
    0x00166914 (A)
    0x400769c0 (A)
    0x400585ac (A)
    0x4005277c (A)
    0x4002a524 (A)
    0x4002a814 (A)
    0x4005287c (A)
    0x400630f0 (A)
    0x001c1874 (A)
    0x00163e2c (A)
    0x00164884 (A)
    0x004a49ec (A)
    0x004a7b0c (A)
    0x004a7a24 (A)
    0x004b44e4 (A)
    0x004b1658 (A)
    0x00169bbc (A)
    0x0016fa7c (A)
    0x0006123c (A)
    0x00586470 (A)
    0x00039014 (A)
    0x00039088 (A)
    0x0005e3ac (A)
    0x000612c8 (A)
    0x000622b4 (A)
    0x0016d6d8 (A)
    0x001662d4 (A)
    0x001668bc (A)
    Global status:
    bInFocus: 1
    bMouseDown: 0
    bInLogic: 0
    bInRender: 0
    CurrentState[128]:
    Current System time: "2012-07-04 16:16:32"
    Memory Stats:
    FreeMemory: 89 MB, 0 KB, 0 B
    TotalUseableMemory: 90 MB, 252 KB, 0 B
    iGO8.EXE 0x07f60002 0x00010000 0x00000000 0x00000003
    0x07fe0002 251 0
    0x07f70002 251 0
    0x400630f0 (A)
    0x40029290 (A)
    0x0063e88c (A)
    0x0063e764 (A)
    0x0063dbd8 (A)
    0x0063dcd4 (A)
    0x00166948 (A)
    0x00166914 (A)
    0x400769c0 (A)
    0x400585ac (A)
    0x4005277c (A)
    0x4002a524 (A)
    0x4002a814 (A)
    0x4005287c (A)
    0x400630f0 (A)
    0x001c1874 (A)
    0x00163e2c (A)
    0x00164884 (A)
    0x004a49ec (A)
    0x004a7b0c (A)
    0x004a7a24 (A)
    0x004b44e4 (A)
    0x004b1658 (A)
    0x00169bbc (A)
    0x0016fa7c (A)
    0x0006123c (A)
    0x00586470 (A)
    0x00039014 (A)
    0x00039088 (A)
    0x0005e3ac (A)
    0x000612c8 (A)
    0x000622b4 (A)
    0x0016d6d8 (A)
    0x001662d4 (A)
    0x001668bc (A)
    Global status:
    bInFocus: 1
    bMouseDown: 0
    bInLogic: 0
    bInRender: 0
    CurrentState[128]:
    Current System time: "2012-07-05 12:03:41"
    Memory Stats:
    FreeMemory: 86 MB, 604 KB, 0 B
    TotalUseableMemory: 87 MB, 856 KB, 0 B
    iGO8.EXE 0x047e0026 0x00010000 0x00000000 0x00000003
    0x0428001e 251 0
    0x07520046 251 0
    0x400630f0 (A)
    0x40029290 (A)
    0x0063e88c (A)
    0x0063e764 (A)
    0x0063dbd8 (A)
    0x0063dcd4 (A)
    0x00166948 (A)
    0x00166914 (A)
    0x400769c0 (A)
    0x400585ac (A)
    0x4005277c (A)
    0x4002a524 (A)
    0x4002a814 (A)
    0x4005287c (A)
    0x400630f0 (A)
    0x001c1874 (A)
    0x00163e2c (A)
    0x00164884 (A)
    0x004a49ec (A)
    0x004a7b0c (A)
    0x004a7a24 (A)
    0x004b44e4 (A)
    0x004b1658 (A)
    0x00169bbc (A)
    0x0016fa7c (A)
    0x0006123c (A)
    0x00586470 (A)
    0x00039014 (A)
    0x00039088 (A)
    0x0005e3ac (A)
    0x000612c8 (A)
    0x000622b4 (A)
    0x0016d6d8 (A)
    0x001662d4 (A)
    0x001668bc (A)
    Global status:
    bInFocus: 1
    bMouseDown: 0
    bInLogic: 0
    bInRender: 0
    CurrentState[128]:
  11. #9
    Jul 2012
    Hi... this is my first post... Before I begin...
    I want get step by step help about install iGO Primo2 (9.6.5.221194) to Sony nv-u93tw and run it from Memory stick. Here is the link of the zip I get ( http://www.sashamilic.me/downloads/Primo2.zip ).
    I have Memory stick (Memory Stick PRO Duo, 4GB, volume name: MEMORYSTICK).
    What I done:
    1. I backup original Mounted volume from device (folder: /Sony/) to my laptop.
    2. Than I unzip the file Primo2.zip to c:\new_navigation.
    I read that I need to do lots of preparation of files (sys.txt and some renaming of files) to make this work, but I`m afraid to brake navigation device. (many guys break it) So I need to someone check the files.
    I need Europe map meanly Sweden.
    What are the next steps.
    Thanks in advance..!!!
  12. #10
    Jul 2012
    I'm new to this forum. I Need help In my Aldi Go Cruise S350, Need help in placing Asia Pacific Maps on the Unit and make it work. Don't Have an Idea on Where to start. I Need steps on how to load maps and make it work on my unit.
    Thanks in Advance.. :-)
