que502 iGo8
Hello all
I have the que502 Gps system with iGO 8 and I need some help.
I want to to put all the lasts maps that available on the system, except of Africa.
I want to use an SD card, whice size I should buy?
could you help me?
thank you
18th August 2012, 23:11
#2
Re: que502 iGo8
I tried googling the version you have, but couldnt find anything other then you asking this question.
First, Id look at the box it came in, there's probably a maximum capacity for the SD card written on there somewhere.
If nothing is listed, Id get a 32gig card. They run about 20 bucks on ebay.
Second, I wouldnt advise putting all maps on the card, how many times in one day will you be driving in Europe, Canada, and Chechnya? It just adds to load up time, and bogs down your system.
Maybe that helps?
