Thread: help with igo primo on chinese double din
    I have been trying to install igo primo to my double din chinese head unit running windows ce 6.0. It currently runs sygic but keep reading that igo is preferred by most people. I managed to get one version working but it only done part postcode searches so wasnt as good as the sygic already installed. All other versions i have tried downloading i have had no sucess in getting working.
    Does anyone have a link to a working version with full postcode search, i have learnt how to put different maps/voices etc , just need a working base to start with.
    mytheuzen's Avatar
    mytheuzen is offline Lieutenant
    Jan 2012
    396
    Re: help with igo primo on chinese double din
    In first, you have to putting space in the post code (i think you do that), and information for research by postcode are integrated into the map. Try with an other one.
    gps-fanboy is offline Corporal
    Feb 2013
    Could anyone please send me a PM with working links for iGO (for at china 2DIN headunit running wince6.0, 600Mhz, 800x480 resolution). Maps of interest is wester europe. Thanx in advande
