Results 1 to 8 of 8
Thread: How can I upgrade iGO8 installed in VolksWagen
    ypefti is offline Staff Sergeant
    87
    Folks,
    I'm absolutely new to iGO nav systems. We bought VolksWagen with installed iGO8 nav system.
    Maps are old and I wanted to update them. I downloaded North American maps iGO8 R3 Navteq 2012.Q4 and now wondering how I can install them.
    Anyone, please help a beginner!
    ant40 is offline Staff Sergeant
    67
    Re: How can I upgrade iGO8 installed in VolksWagen
    Quote Originally Posted by ypefti View Post
    Folks,
    Just replace the content of content/map (hnr, building, poi) with new ones (if you can access the folders).
    janch is offline Captain
    In Hell!
    668
    192
    Quote Originally Posted by ant40 View Post
    ..and off course it won't work, due to original software installed in VW system (SD). You need to install crack*d version iGO software in order to use those (or any other) maps with "unofficial" update method...
    87
    Ok, it's at least something already.
    I downloaded maps from this forum - http://gpsunderground.com/forum/igo-...nada-full.html
    How would I know if this is cracked or not cracked one ?
    Thanks, guys!
    67
    Thanks, guys!
    If you downloaded it from here - It's cr***ed
    87
    It's technically not exactly "from here". The link to android-zone was posted at this forum but the content was elsewhere also. Should I treat this content as ready for installation.
    Any idea about the logo ? I assume it should stay.
    And another question. What are *.dem files ? Should I just disregard them ? They are in "Dem" directory.
  7. The Following User Says Thank You to ypefti For This Useful Post:
    Luis is offline Sergeant
    Portugal
    49
    39
    Hi ypefti
    It is very important to know the resolution of your gps screen, maybe 800x480 ?? so you need igo8 for Windows CE 5 or 6 I think, not android, and with "data" and "branding" for the same resolution. This is very important, more than the dem files you want to know now. When you got igo8 working, then you can put dem files, ok?
    Best regards.
    "Don't send me PM when there is a topic to place the question"
    67
    Copy-paste from Google -
    Overview: .dem files gives to iGO the ability to show an overhead view of the map (with terrain colouring/shading) where you can pin-point your precise destination. In 3D mode the view changes into a spectacular real point of view. In 2D mode it shows colorful areas depending on terrain height. Look at the screenshots.
