Results 1 to 10 of 13
Thread: Guide to installing iGo8 on Mio C510 and C710
    Essex UK
    209
    HOW TO SETUP IGO8 ON A MIO C710 WITHOUT HACKING IT?
    This method should make it possible to, even after a hard reset, just start up iGO by the MIOMAP pictogram (main menu MIoC710)
    You need a iGO program for this. I suppose you have it ready on your PC.
    Step 1
    See you have a back up of your Mio so you are able to set it back in the original state !! Very important !!!
    Step 2
    Unzip or Unrar (if necessary) the iGO8 on your PC.. Now you should have a folder called iGO8.
    Step 3
    Copy these lines into a notepad
    [folders]
    app="%SDCARD%\iGO8"
    [interface]
    resolution_dir="320_240"
    maxzoom2d=6000000
    show_exit=1
    show_timezoneslider=1
    reset_os_timezone=1
    landscape=1
    [timezone]
    sync_os_timezone=0
    reset_os_timezone=0
    [debug]
    skip_eula=1
    smart_2d=1
    slowsim=1
    loop_sim=0
    show_speed_limit=1
    show_tmc=1
    speedcam_enabled=1
    show_arrows_on_route=1
    [rawdisplay]
    class="landscape"
    screen_x=320
    screen_y=240
    [sound]
    sound_q_length=200
    queue_length=200
    [speedcam]
    enable_at_startup=1
    disable="_SUI", "_GER", "_AUT"; for Europe
    [map]
    auto_nightmode=1
    [msnd]
    msnd.start=0
    [tmc]
    source="gns"
    port="COM,1"
    [gps]
    source="nmea"
    port="COM,2"
    Save it and name the file sys.txt. Save it on your PC for now.
    Step 4
    Now replace the original sys.txt (in the iGo folder) with the sys.txt just made.
    If you have in the iGO8 folder another folder named '2577', delete it
    When in the iGO8 folder there is a file called either 'application.dat' or 'iGO8.exe' rename it to 'miomap.exe'
    Rename gpstmc.dll to gpstmc.old
    Next copy the complete iGO folder onto a sd card
    Step 5
    Put the sd card in the sd slot of the Mio.
    Turn on the device. Press and hold the plus (+) and menu button (at the same time). Do a soft reset
    (on the bottom side of the device is a reset hole' to be pressed by a stylus, or paperclip)
    Keep holding the plus (+) and menu button pressed until you get a message COPY .
    Click 'NO' - you get an error message - Click 'OK'
    If all is well, Windows CE start screen appears, Click on the Windows logo, go to PROGRAMS, choose WINDOWS EXPLORER.
    Double click on STORAGE CARD, go to iGO8 folder, select miomap.exe, copy this file (menu-edit-copy)
    Click the BACK arrow and go to MY FLASH DISK\MIOMAP\MIOMAP. Next paste (menu-edit-paste)
    Go back to IGO8 folder on storage card and copy sys.txt (menu-edit-copy)
    Do a soft-reset (the hole at the bottom )
    From now on, iGO will start up by pressing the pictogram MIOMAP in the main menu
    Remarks
    Disable scrolling street names. to prevent OUT OF MEMORY errors
    Some (older) igo's create by themself OUT OF MEMORY errors on a C710. If that happens, do a google search for the latest data.zip (V10) and branding.zip,
    Replace the ones on your sd card.
    Enjoy!
    Credits to Guardian who Pm'd me with this guide.
  2. The Following 2 Users Say Thank You to matty538 For This Useful Post:
    Re: Guide to installing iGo8 on Mio C510 and C710
    hello Matty538
    thanks for your method....
    I have a little problem on my C510 .....when I press the pictogram MIOMAP in the main menu, star the old miomap ...
    If I cut the old miomap.exe (inside Myflasdisk\miomap\miomap) the picogram MIOMAP don't work but if I press two times the icon new miomap (shortcut from storage card/igo8) the IGO8 application work perfectly !!!!
    /from the window CE). In conclusion, don't work the shortcut from the pictogram MIOMAP and the application miomap in the flasdisk/miomap/miomap. Can you help me?
    Thnaks
    Alessandro/Florence/italy
    Essex UK
    209
    You would be best asking Guardian who is credited in the post, I merely copy and pasted what he sent me by PM as a suggestion for this section, I have no hands on experience with these models unfortunately.
    Guardian is offline Corporal
    16
    copy also sys.txt to MY FLASH DISK\MIOMAP\MIOMAP
    And then again soft reset
    Quote Originally Posted by Guardian View Post
    Great !!!!!!!! Now work perfectly.... Thank you very much !!!!!!!!!!!
    16
    No tnx all credits go to the Belgian guy Clooneys.
    He wrote the whole thing.
    p.s I know it worked did 3 MIO's already with this guide.
    @matty538 please add the copy off sys.txt after copying miomap.exe
    Hi, I would like to run iGo from the flash drive, without an D card, could you please tell me how to edit the sys file ([folders] app=" ? /iGO8") so that it will recognize where it is?
    I managed to run it of the sd card following this thread, but really don't know how to run it only from the flash.
    thank you
    Essex UK
    209
    Where does it need to go, sys.txt is already mentioned as being copied across.
  10. #9
    16
    Ad red text lines
  11. #10
    Essex UK
    209
    Got it cheers, original thread edited.
  1. 20th April 2012, 16:13
  2. 22nd January 2012, 17:32
  3. 14th November 2011, 15:41
