Results 1 to 7 of 7
Thread: iGo HD2 ?
    pnjboyzz is offline Private
    iGo HD2 ?
    Hi All,
    i am trying to find the valid links for Igo on HD2. they all appears to be down.
    can anyone please direct me to valid links for IGO...
    i cant find any IGO app for HTD2... i believe its called PNA.
    thaks;
    Essex UK
    209
    Re: iGo HD2 ?
    HTC HD2 is a PDA.
    Some PNA versions of iGo are patched to work with PDA though. Ideally you want 8.3.2.138649 which is a PDA only version.
    Alternatively you can use 8.3.4.142975 which is patched to work on PDA and PNA.
    Im sure if you use google to search the version numbers you will get lucky, id upload myself, however im a little busy at the moment.
    Re: iGo HD2 ?
    Quote Originally Posted by matty538 View Post
    HTC HD2 is a PDA.
    thanks for the info...
    i have the files but dont know how to use them..
    i have htc hd2 and i do not see any CAB file in this folder..
    help please.
    can you please provide me some instruction on make this Igo work.
    thanks.
    rgs
    rgs is offline Sergeant
    30
    40
    Re: iGo HD2 ?
    There's no CAB. The directory structure should look like:
    content
    license
    save
    branding.zip
    data.zip
    igo.exe
    sys.txt
    Just copy these on your SD Card into a folder named "iGo" and launch igo.exe
    Re: iGo HD2 ?
    Quote Originally Posted by rgs View Post
    content
    license
    save
    branding.zip
    data.zip
    igo.exe
    sys.txt
    Thanks... it works... but when i rotate the screen, half of the scree gets choped off.... any solutions
    Re: iGo HD2 ?
    HTC HD2 is a PDA.
    need help from you.
    IGO8 shows all the landmarks such as buildings, etc,..
    i try changing several settings but no luck.. can you please suggest the settings step by step.
    thanks
    Essex UK
    209
    Re: iGo HD2 ?
    Quote Originally Posted by pnjboyzz View Post
    need help from you.
    thanks
    You will need the .3dc and .3dl files for you relevant country,these go in the content-buildings folder. If you have these I will also point out that they only display in certain cities. For example for me the nearest place that shows 3d landmarks is London.
    You can also get 3d terrain, again for this you will need the .dem file for you relevant country, however yet again this only seems to appear in certain areas, mainly where there are large and consistent variations in hieght.
