Thread: Help with Primo Sys.txt for system shut-down
    joking742's Avatar
    67
    I'm trying set up Primo to run without an unlock to make idiot (good luck right!) proof for my other. Is there a sys.txt entry to get (exit) button to shut down the system. Shut down works great when I turn off ac, but I'm sure she will hit the main menu (exit) button sometime which causes freeze. (I miss the old igo sys.txt posts that had everything mapped)
    If there isn't one...could you direct me to the skin location .ui that I could redirect to a shutdown program?
    959
    Re: Help with Primo Sys.txt for system shut-down
    Kind of late with this response, but ............... what you are describing is generally experienced on devices that are starting Primo directly (no shell, or menu system). I solved this problem for the Insignia NS-NAV01, and I may be able to work out the problem for your device also, if you provide some specifics about the device and how your starting Primo.
    Oct 2011
    Dohcacr,
    How did you solve it for the Insignia NS-NAV01?
