Thread: Igo Primo "detecting gps receiver"
    pballernyc is offline Lance Corporal
    Hello everyone, I currently have Igo Primo installed on my 7" Chinese GPS PNA running Win CE 5.0 800 x 480. I'm not sure if I set up the sys.txt correctly. Basically, the program opens, but in the upper left corner, it keeps saying "detecting gps receiver." When I was using Igo 8.3, I saw my settings were Com 2, and the baud rate worked on both 4800 and 9600.
    If someone could please show me how to properly set up my sys.txt or anything else that might help, I would greatly appreciate it.
    Please help.
    Re: Igo Primo "detecting gps receiver"
    Mine is royaltek, port 3, 9600 I think, it should have an autodetect, as soon as I put in Royaltek it was able to find it.
    Sorry just noticed it is primo, I think you need to add the above into your system file, not forgetting to delete your save file before reloading.
