Thread: screen orientation on IGO Primo?
    mygps2010 is offline Staff Sergeant
    96
    25
    Question screen orientation on IGO Primo?
    At the moment it works in landscape with the HD2 phone in such a position that the buttons at the bottom of the phone are on the left hand side and I would like it show landscape to right?. I cant find it on settings!
    thechachman is offline Corporal
    Feb 2011
    22
    Re: screen orientation on IGO Primo?
    Quote Originally Posted by mygps2010 View Post
    You'll have to add a new skin for the interface which moves things around, you can try the following edit in sys.txt but that will just rotate the display 180 degrees:
    [screen]
    preferred_orientation=X ( if currently 0 - change to 2, or if currently 1 - change to 3)
