Thread: How can i put igo and igo primo mnaps in sd card
    verdugo2009 is offline Staff Sergeant
    88
    37
    Hi i have a gps converted to iGO.With iGO Amigo installed in internal memory but cant put more than one map i try to put the other europe maps in sd card but the program doesnt recognize them even putting in the sys.txt the corresponding line to it.Some boddy have an idea of how can i do it.Thanks
  2. The Following User Says Thank You to verdugo2009 For This Useful Post:
    Oct 2011
    Re: How can i put igo and igo primo mnaps in sd card
    will a florida US map work if dragged over to a euro igo amigo ????????????????
    959
    Have you tried putting the maps in sdcard*/igo/content/maps/
    and adding
    [folders]
    sdcardpath="\sdcard*\igo"
    has_secondary_root=1
    * of course, you would need to know the correct wince name for your sdcard.
    959
    If your licenses support it.
