Originally Posted by
Tenareze
Thank you. I did install the TTS voice package, but it did not work on the loaded version of Primo. However, it does work with your International Edition, which is very nice. I still cannot enable voice alerts for speed cameras. I have used the diMKaWerk_1137 skin, but I get no voice, although the road names are pronounced. I also did not get a sound (beep) alert for the speed camera, maybe I should alter the beep_mute line in the sys.txt file, but I am not sure what it does.
One point. I had to disable network in the sys.txt file as I kept getting "Connection error. Check your network connection" I don't have this feature on my GPS.
Great program, thanks again.
Ten
