Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 201 to 210 of 213
Thread: TTS Pro Voices & Simple Voices for Primo 2.0 and for Primo 1.2
  1. #201
    Re: TTS Pro Voices & Simple Voices for Primo 2.0 and for Primo 1.2
    Hi.
    Thanks for all the work gone into the text to speech for Igo.
    Have installed all dll's and tts packs and she speaks!!!!
    One thing i have noticed she says "Saint" when St. is the abbreviation for Street.
    Is there an easy way to correct this or shall i verbally correct her while driving.
    Thanks again.
    Thinker.
  2. #202
    Quote Originally Posted by Thinker View Post
    Thanks again.
    Thinker.
    I have a similar problem. I am using the English TTS Pro voices in the US with Q3 2012 maps. All of the voices say strange things like:
    "drove" instead of "drive"
    "EB", "WB", "SB", "NB" instead of "East, West, South, or North Bound"
    "blvd" instead of "boulevard"
    "turn before the petrol station" instead of "turn before the gas station"
    I can tolerate the above issues, but the one I hate the most is this: "Turn right onto 20 Tee H street" instead of "Turn right onto twentieth street" or "Turn left onto 23 R D street" instead of "Turn left onto twenty-third street". How can the voice not know the "th" or "rd" part of numbered streets?
  3. #203
    Feb 2013
    thank you
  4. #204
    Thanks!!!!
  5. #205
    thanks!!!!!
  6. #206
    Thanks for all the good work you guys put in. I read the entire thread, downloaded the TTS torrent and installed following all the instructions. On my Toshiba Excite 7.7 with iGo Primo 2.0 the TTS Pro button is grey and I'm missing the file "vautov5.dll". Where can I get only this missing file?
    Cheers!
  7. #207
    Quote Originally Posted by DPolex View Post
    Well, I found the file at [url=http://dll-files.org/]; however that didn't help, my TTS option is still dead. Can anyone help? Thanx!
  8. #208
    I also have the same problem, copied all as per instruction but TTS is still greyed out.
    Is there some special way to get the TTS working ?
    I have Primo 2.4 on micro-sd in a car radio from marquant, I guess its a windows device but m not shure
  9. #209
    merci je vais essayer pour primo
  10. #210
    are there any novelty english voices available?
    Regards
