Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 208
Like Tree29Likes
Thread: TTS Pro Voices & Simple Voices for Primo 2.0 and for Primo 1.2
  1. #21
    zervdim's Avatar
    zervdim is offline Lieutenant
    398
    29
    Re: TTS Pro Voices & Simple Voices for Primo 2.0 and for Primo 1.2
    Quote Originally Posted by Tenareze View Post
    Thanks. The sys.txt file provided appeared to already contain the lines mentioned in the readme.txt file. Maybe there have been some changes I did not notice.
    I am not sure how to check the voices in the dimka skin.
    Ten
    If you are using language different than english then you must go to sys.txt copy the lines that I have in the readme file for TTS Pro and make 31 translation as i described in read me file.Don't forget to copy in sys.txt all the other lines that enable TTS Pro to speek more loudly.
    In dimka skin you have to select not ultravoice-igo8 but sounds=Primo.
    Then you must reach satellites and add some speedcameras or Proximate alerts from the menu of Dimka.
    Make a small route near you and then you can hear the TTS announcement.
  2. #22
    Tenareze is offline Private
    Jan 2012
    I was using the wrong diMKa skin and have now changed to Primo voices, but I still have no voice or sound alerts for speed cameras. I have sound and voice alerts for over speeding and I can see the cameras on the screen. I think I am missing a component or have not selected the correct settings. All is set to English.
    Any ideas where to look next?
    Ten
  3. #23
    Jan 2012
    Sent twice by mistake
  4. #24
    zervdim's Avatar
    398
    29
    Ten
    Sorry,but I think that you haven't read the instructions.
    First of all read the instructions.
    Write the .dll in the root of Primo
    Write the voices to the path: Primo/content/voice
    Write the file tts_loq to the path: Primo/ .
    Write the sys.txt for the speedcameras and Proximate alert to your sys.txt
    Run Primo, go to the menu of dimka and select voice a voice that is TTS Pro Dave-zervdim or TTS Pro-Susan-zervdim (those voice are TTS Pro voices and can give you the announcemnet of the speedcameras) if you hear Hello I am DAVE it means that everything is fine with the TTS Pro.
    If you select a simple voice that don't support street names announced then you never will hear the Speedcameras.
    Then go back to the menu of dimka and selct not igo8 =voice but voice=primo voice.
    Get satellite and from the main screen of dimka select a speedcamera, make a small root near your adreess and then you can hear the TTS Pro.
    Don't forget to copy to your sys and the other lines that make the TTS louder.
  5. #25
    Jan 2012
    Yes it works now, I see what I was doing wrong. I had not set the speed correctly and was not going fast enough to trigger the alerts. I see it is possible to set the delta speeds + or -. In my country speed camera alerts have been outlawed and so vocal guidance is essential. You also have to be careful not to switch off the sound by pressing the bottom left corner of the screen. Easy to do by mistake. Just press again to switch on the sound.
    If the auditory guidance and alerts are important for you, I think it best to use the default skin rather than the dimka skin. It is not so easy to turn off the sound inadvertently.
    Ciao
    Ten
  6. #26
    grumpygregg is offline Private
    Jan 2012
    usa english I 'm in canada thanks
  7. #27
    zervdim's Avatar
    398
    29
    Quote Originally Posted by grumpygregg View Post
    I search a lot to find simple voice for canada, but I can't find yet.
  8. #28
    Jan 2012
    Quote Originally Posted by zervdim View Post
    I am looking for the tts pro english to use with primo 2. The wife liked the way the old software said the street names. God knows what the wife wants the wife gets once again thanks
  9. #29
    zervdim's Avatar
    398
    29
    I have all TTS Pro in the first post, look here please:
  10. #30
    Jan 2012
    thank you. Every time I tried to down load it before it said I needed to become a mernber to access it. today it came up with the download button. once again Thanks
