  • 1 Post By Juraj91
Thread: Edit TTS voices IGO Primo
    boblejeune is offline Lance Corporal
    Feb 2012
    Does someone know how to edit the TTS voice in order not to pronounce the street number but the street name, or a combination of streetname and streetnumber?
    we have a lot of N... (National) streets in Belgium, but they also have a street name, in most cases the N number is not visible on the street and by default the GPS TTS only says the N+number instead of the street name.
    or maybe someone know's a forum where TTS editing is handled?
    Grtz
    duffer is offline Captain
    Jun 2011
    660
    26
    Re: Edit TTS voices IGO Primo
    Quote Originally Posted by boblejeune View Post
    Grtz
    That is usually a map maker thing. You might need to use a non-TTS voice.
    kamoteka is offline Master Sergeant
    147
    It is risky to edit TTS voices and you may end up with a non-working voice if you mess it up.
    Instead, try putting this on your sys.txt :
    [tts]
    always_say_road_names=2
    skip_road_numbers=1
    Aug 2012
    Hello
    Search TTS Voices for Igo Primo Android device.
    Has one or knows the voices of a link.
    Thank you
    Juraj91 is offline Lance Corporal
    Feb 2013
    thanks for the manual kamoteka!
    curius likes this.
