Results 1 to 8 of 8
Like Tree2Likes
  • 2 Post By mikedegan78
Thread: TTS Pro Voice Issue
    mikedegan78 is offline Private
    TTS Pro Voice Issue
    I have installed IGo Primo and the TTS Pro voices on Android ICS, and when I select the english voice. THe voice is very slow and slured, am I missing a seeting in the sys.txt file that sets the speed of speech?
    giorgos148 and boygps like this.
    OttoNavi is offline Lance Corporal
    Mar 2012
    Ontario, California
    Re: TTS Pro Voice Issue
    I encountered the same thing. Any solution to this yet??
    Senrap is offline Corporal
    21
    22
    Hi guys. I had the same problem but I think I have sorted it by making some changes to the sys.txt.
    Here's mine and I hope it helps.
    If anybody reading this sees anything untoward or unnecessary in my sys.txt, I shall be pleased to hear from you.
    Edit: In fact, I do still have the problem but with the SVOX voice and not Loquendo which seems to work okay!
    [device]
    type="android"
    [autorad]
    disabled=1
    [interface]
    extra_settings=1
    capture_to_jpeg=1
    save_checksum=0
    show_tmc=1
    show_tmc_eventlist=1
    clearcity=1
    collect_statistics=0
    defaulttilt3d=7600
    drive_carefully=0
    exit_on_restart=0
    laneinfo_signpost_enabled=1
    mapfontscale=180
    minzoom2d=30
    max_flag_distance_3d=2000
    maxzoom2d=6000000
    show_bt=1
    show_bugreport=0
    show_detailed_posinfo=1
    show_exit=1
    show_mapchanger=1
    show_minimize=1
    show_phone=1
    show_programs=1
    show_tutorial=1
    show_wifi=1
    shutdown_time=0
    signposts_without_lineinfo=0
    skin="ui_android"
    start_navigation_time=5
    ui_labs=1
    use_big_lang_flag=1
    experimental_features=1
    recalc_voice=1
    show_glonass=1
    [gps]
    location_net=1
    location_gps=1
    background_navigation=1
    location_log=0
    location_log_filename="gpslog/LocationManager"
    [tmc]
    source="gnse"
    internal_tmc_name="gnse"
    port="/dev/gnstmc,0"
    [modules]
    ITMC_STATION_SELECTOR="TMC_STATION_SELECTOR_NULL"
    IFM_STATION_CACHE="DUMMY_TMC_STATION_CACHE"
    ;[rawdisplay]
    driver=engine
    screen_xy="800_480:800x442/480x762"
    [rawdisplay]
    driver=engine
    screen_xy="800_480:800x480/480x800"
    ;[android]
    tablet=1
    has_physical_home_button=0
    [android]
    fullscreen=1
    tablet=0
    show_status_bar=1
    ;getdeviceid_gemini=1
    ;check_for_dead_links=1
    [feature]
    back_exit=1
    back_button=1
    signpost_nightshading=1
    signpost_coloring=1
    show_truck_info=1
    [2d]
    guidancearrow_disappearlevel=600
    guidancearrow_maxshift=12
    max_icons_shown=3
    maxcarsize=120
    maxcarsize_zoomlevel=200
    maxguidancearrowsize=65
    maxguidancearrowsize_zoomlevel=0
    mincarsize=100
    mincarsize_zoomlevel=2000
    minguidancearrowsize=20
    minguidancearrowsize_zoomlevel=1200
    show_planned_route_arrows=1
    traffic_lights=1
    [3d]
    usepolyfarroads=0
    fade_around_cursor=1
    fade_distance_for_car=1
    fade_distance_for_guidance_arrow=1
    fade_overlap_tolerance=1
    max_pois=10
    max_pois_on_horizont=5
    max_speedcam=5
    max_speedcam_on_horizont=5
    planned_route_contour_width=8
    planned_route_track_width=5
    planned_route_track_contour_width=1
    planned_route_visible_behind_mountains=1
    show_guidance_arrows=1
    show_guidance_strip=1
    use_all_building_textures=1
    [3d_config]
    disable_roadsign_navigation_mode=0
    max_pois_on_horizont=7
    roadsign_always_framed=1
    roadsign_bitmaps=1
    roadsign_lines_per_screen=7
    rotated_roadsigns=1
    [debug]
    skip_eula=1
    imei="000000000000000"
    screenshotsavecameraini=0
    screenshotfilename="android_linked_root/debug/img_%02d.jpg"
    show_battery_percent=1
    earth=1
    enable_roadshadow=1
    enable_roadsign=1
    hnr=1
    raster_quality=1
    show_hnr=1
    show_oneway=1
    show_oneway_3d=1
    show_pedestrian=1
    show_networkservices=1
    enable_landmark_occlusion=1
    speedcam_enabled=1
    gnome_dem_files=1
    autosave=1
    autosave=1
    [map_update_checker]
    enabled=0
    [map]
    2dheadup=1
    3d_default_tiltlevel=9000
    3d_max_tiltlevel=9000
    3d_max_zfar=5000
    3d_max_zoomlevel=600
    3d_min_zoomlevel= 10
    3d_scale_carmodel=1
    3dcarsizemax=12000
    3dcarsizemin=8000
    3dcarsizemul=30000
    raster_in_2d=0
    raster_in_3d=0
    raster_2d_high_quality=1
    raster_3d_high_quality=1
    set_max_bubble_labels=5
    [roundaboutcam]
    enabled=0
    centery=20
    [navigation]
    env_zone_warning_distance=500
    show_city_in_next_street=1
    show_city_in_next_street_distance=1000
    show_countrychange=1
    show_current_city=1
    track_simulation_speed=1
    autoreplan_action="AUTO"
    gps_pos_to_road=1
    junction_view_at_maneuver=1
    junction_view_distance=200 ;300
    junction_view_distance_ramp=400 ;300
    junction_view_distance_highway=400
    junction_view_on_highways_only=1
    junction_view_type="NNG"
    passed_guidance_arrow_hide_distance=-1
    sim_speed_factor=1
    simple_crossborder_warning=1
    stop_at_tunnel_end=1
    use_duration_for_tunnel=1
    junction_view_blink_time=1000
    junction_view_blink_time_no_lane=1000
    parking_ad_enabled=1
    congestion_ad_enabled=1
    quickdetour_enabled=1
    [hnr]
    ignored_missing_country_ids=*
    [route]
    correctness=80
    guidance_at_highway_entry=1
    guidance_at_highway_exit=1
    hnr_ignored_missing_country_ids=*
    minimum_hnr_distance_km=100
    allow_offroad_waypoints=1
    [folders]
    linked_root_list="/mnt/sdcard/iGO /mnt/ext_sd/iGO /mnt/sdcard/external_sd/iGO /sdcard2/iGO /sdcard/iGO /sdcard/sd/iGO /mnt/sd/iGO /mnt/iGO /storage/iGO /sdcard/external_sd/iGO"
    [poi]
    picturepoi_scan="/mnt/sdcard/myPictures"
    picturepoi_nonrecursive_scan="/mnt/sdcard/myPictures"
    ;enable_icon_fight=1
    ;group_poi_icons=0
    ;max_icons_shown=40
    ;max_quicksearch=80
    ;poi_grouping_distance=0
    ;traffic_lights=1
    ;use_multi_poi_icon=0
    ;featured_provider=0
    ;featured_provider=""
    [network]
    available=1
    [tmc-http]
    enabled=1
    servers.size=1
    servers[0].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-iphone/0/"
    [naviextras]
    boot_service_address="http://zippy.demo.naviextras.com/services/index/rest/2/boot"
    [services]
    server_addr="https://android.naviextras.com"
    software_download_location="https://android.naviextras.com/to/dlapk_prestigio-gv7777"
    [loading]
    ;show_progressbar=1
    ;progressbar_x=20
    ;progressbar_y=5
    ;progressbar_end_x=20
    ;progressbar_end_y=5
    show_statustext=1
    ;[mydata]
    max_favorites=80
    max_histories=80
    cityhistory_size=1000
    max_quicklist=250
    [dynamiccompressor]
    compressor=1
    ratio=9
    gain=9
    [warning.driveralert.settings]
    max_display_count=3
    preactivate_distance=300
    show_timeout=10
    show_vehicle_pictograms=1
    warn_method=2
    [warning]
    approach_beep_sound=none
    approach_beep_spoken_type=0
    is_spoken=1
    overspeed_sound=0
    skin_audio_path="UK"
    speak_tts_only=1
    speedcam_continuous_approach_beep_when_tonal=0
    speedcam_enabled=1
    speedcam_max_lookahead=1500
    speedcam_maxdistance_from_road=10
    speedcam_soundtype_1=2
    speedcam_warning=1
    speedlimit_ua_correction=0
    ;speedlimit_warning=1
    speedlimit_warning_visual=1
    speedlimit_warning_voice=0
    speedwarn_alt_tolerance=110
    speedwarn_tolerance=110
    ;warn_distances=150:2000,140:1600,130:1400,120:1200,110:1000,100:800,90:600,80:500,70:400,60:300,50:200,40:100
    [tts]
    ttspro_da_voice_enabled=1
    always_say_road_names=3
    automatic_direction_conversion=1
    announce_exit_directions=1
    announce_street_name=1
    skip_exit_numbers=1
    tts_buffer=131072
    tts_logics=3
    priority="HIGH"
    tts_speedcam_sounddelay0=90
    tts_speedcam_sounddelay1=140
    tts_speedcam_sounddelay2=140
    tts_speedcam_sounddelay3=140
    tts_speedcam_sounddelay11=90
    tts_speedcam_sounddelay17=140
    [timezone]
    patch_dst=1
    reset_os_timezone=0
    sync_os_timezone=0
    sync_time=1
    use_auto=1
    [timezones]
    timezone_key="Time Zone"
    use_timezone_setting_fix=1
    use_new_timezone_ini=1
    [sound]
    alarm_volume=255
    csv_voice_enabled=1
    dev_channels=2
    ding=0
    ding_muted=1
    dynamic_volume_autocalc_maxvoicespeed=0
    dynamic_volume_maxspeed=130
    dynamic_volume_minspeed=30
    dynamic_volume_type=1
    dynamic_volume_os_amplification_step=10
    dynamic_volume_os_volume_max=255
    dynamic_volume_voice_volume_max=100
    dynamic_volume_voicemaxspeed=100
    effect_volume=60
    guidance_volume=255
    maneuver_chimes=0
    mic_volume=255
    mute_os_key=1
    os_volume=255
    pause_mp3_sooner=1
    queue_length=200
    use_method=1
    user_volume=175
    welcome=speech
    welcome=speech1
    wheelsound=0
    [speedcam_category:0]
    activated_min_speech_repeat_delay=-1
    activated_speech="Caution Speed Camera"
    activated_spoken_type=speech
    overspeed_spoken_type=none
    warn_distances="110:500,90:300,60:200,20:150"
    skin_repeat_sound = "speedcam_rep"; (sound hitting again, in quotes name wav file)
    skin_repeat_distance = 100, (distance hitting again in meters)
    [speedcam_category:1]
    activated_speech="Caution Mobile Speed Camera"
    skin_repeat_sound = "speedcam_rep";(repeating alarm wav file name in quotation marks)
    skin_repeat_distance = 100,;(the re-activation distance in meters)
    [speedcam_category:2]
    activated_speech="Attention Traffic Camera"
    [speedcam_category:3]
    activated_speech="Caution Traffic Light"
    [speedcam_category:4]
    activated_speech="Caution Average Speed Camera"
    [speedcam_category:6]
    activated_speech="Caution Railroad Crossing"
    warn_distances="110:1000,90:900,60:600,20:200"
    [speedcam_category:7]
    activated_speech="Caution Bus Lane Camera"
    warn_distances="0:200"
    [speedcam_category:8]
    activated_speech="Caution High Accident Zone"
    warn_distances="0:300"
    [speedcam_category:9]
    activated_speech="Caution School Zone"
    warn_distances="0:250"
    [speedcam_category:10]
    activated_speech="Attention Town Entry Point"
    [speedcam_category:11]
    activated_speech="Attention Radar Intimidation"
    [speedcam_category:12]
    ;activated_speech="Attention Toll Booth"
    activated_speech=""
    speedcam_maxdistance_from_road=50
    warn_distances="110:1000,90:800,60:500,20:100"
    [speedcam_category:13]
    activated_speech="Attention Hospital"
    [speedcam_category:14]
    activated_speech="Fire Station"
    [speedcam_category:15]
    activated_speech="Caution Congestion Charge Zone"
    [speedcam_category:16]
    activated_speech="Caution Give Way"
    [speedcam_category:17]
    activated_speech="Caution Dangerous Junction"
    [speedcam_category:18]
    activated_speech="Caution Speed Breaker"
    warn_distances="0:150"
    [speedcam_category:19]
    activated_speech="Caution Children and Pedestrians"
    [speedcam_category:20]
    activated_speech="Caution Dangerous Turn"
    [speedcam_category:21]
    activated_speech="Attention Tunnel"
    [speedcam_category:22]
    activated_speech="Caution Dangerous Road"
    [speedcam_category:23]
    activated_speech="Attention Police Station"
    [speedcam_category:24]
    activated_speech="Caution Dangerous Area"
    [speedcam_category:25]
    activated_speech="Caution Black Spot"
    [speedcam_category:26]
    activated_speech="Caution Closed Road"
    [speedcam_category:27]
    activated_speech="Attention Congestion"
    warn_distances="0:500"
    [speedcam_category:28]
    activated_speech="Caution Constriction"
    [speedcam_category:29]
    activated_speech="Caution Low Visibility"
    [speedcam_category:30]
    activated_speech="Caution Low Bridge"
    [speedcam_category:31]
    activated_speech="Caution Dangerous Point"
    [other]
    demo_enabled=0
    [lua]
    rastermaps=1
    [gestures]
    border_width=200
    border_height=200
    movement_distance=70
    liway is offline Lance Corporal
    36
    1. If you are using the system or Pico TTS, you may have the "slow and slured" problem. You have to change the "Speech rate" in Settings to suit. Although I've corrected the problem using the SYS.TXT (sorry I can't recall what's the way now), the simple and reliable way is to go to the system setting and correct the speech to a faster rate over there, by trial and error. Once you set the correct rate, the slurness will be gone.
    2. Better still, you just download some TTS, like IVONA (still free now) and SVOX. Then go to system settings and select the TTS default voice before running iGO/Primo. This will save you a lot of trouble.
    36
    Double post. Deleted.
    evangelos68 is offline Lance Corporal
    Oct 2011
    didnt find solution yet i have the sam problem with acapella and svox tts but not with loquendo.when ichoose one of the first two the first time igo primo works fine but the second time it slures and have slow rate speech .if i change the speech rate to higher speed th first time its okey .After using igo for second time low speed happens again.Both acapella and svox have the problem and i think that happened after i install loquendo.Itryied unistall and delete anything of loquendo but problem continews to be there. any help please
    duffer is offline Captain
    Jun 2011
    656
    26
    Did you try deleting your save folder?
    Oct 2011
    i did nothing happend i even reset my htc one s same problem if i restart phone its working fine if i close igo the next time same slow speech with svox and acapella not with loquendo
