THIS FILE ARE IN TORRENT-FILE AND YOU HAVE TO USE UTORRENT OR SIMILAR TORRENT-DOWNLOADER
Just all simple voices to iGO and Primo. And some extended voic, Lua and TTS voices also in this pack
This pack have 201 voice-files
Unzip the big file you have download and copy the voice .zip files (Do not unzip the .zip voice files) to the path: Primo/content/voice
Size in the file are 393MB
All Voices are in one single torrent file, use what you need and delete the rest.
<<<Download>>>
Please Remember To Seed Back To Keep Torrent Alive
Have fun guy's
Are these OK for Android?
I couldn't find the answer, I don't even know if I can post it here, but here we go... what's the difference between TTS, TTS Pro, TTS Pro V6, Loquendo, Extended, Lua, Nuance...?
Thanks![]()
Most of the Italian voices give me the message "unsupported voices, please see the log" at boot; only 2 of 19 work.
However i cannot find any log except crash.txt but it only reports the message itself and nothing else.
I run iGo Primo 2.0 9.6.5.211211 on a Route66mini
Thank you very much - extremely helpfull
Keep up the good work - I/we are sure to need it again![]()
