Results 1 to 10 of 12
Like Tree2Likes
Thread: iGO Primo TTS PRO NUANCE V8 Edition
    788
    151
    THIS FILE ARE IN TORRENT-FILE AND YOU HAVE TO USE UTORRENT OR SIMILAR TORRENT-DOWNLOADER
    New Edition 20/4/2012 of Nuance TTS Pro Voices by Zervdim & ScorpioPirate
    Arabic TTS Pro V8 Voice Waleed (Too many thanks to furat52)
    Belgium TTS Pro V8 Voice Magda (Too many thanks to chatikib)
    Brazilian TTS Pro V8 Voice Nausicca (Too many thanks to galonet)
    Czech TTS Pro V8 Voice Faidra (Needs Translation to dictionary voice file only)
    Danish TTS Pro V8 Voice Ida (Too many thanks to ScorpioPirate)
    Netherland TTS Pro V8 Voice Kasandra, Odysseus (Too many thanks to chatikib)
    English TTS Pro V8 Voices Iasonas, Medea
    USA TTS Pro V8 Voices Ira, Paris, Penelope
    Finland TTS Pro V8 Voice Menelaos (Too many thanks to knoj)
    French TTS Pro V8 Voice Virginia
    Germany TTS Pro V8 Voices Calypso, Electra, Zeus (Too many thanks to Nico)
    Hungary TTS Pro V8 voice Ariadne (Need Translation only inside the dictionary voice file)
    Indonesian TTS Pro V8 Voice Iliada (Too many thanks to Batojatsu)
    Itlalian TTS Pro V8 Voice Hermes, Silvia
    Polish TTS Pro V8 Voice Areti (Too many thanks to Andrzei)
    Romania TTS Pro V8 Voice Ermioni (Too many thanks to Gabriel)
    Russian TTS Pro Voice Natassa (Needs translation inside the dictionary voice file)
    SloVak TTS Pro V8 Voice Artemis (Too many thanks to Newbie 414)
    Spanish TTS Pro V8 Voices Apollo, Dimitra (Needs translation inside the dictionary voice file)
    Sweeden TTS Pro V8 Voices Poseidon, Erasmia (Too many thanks to Knoj)
    Portuguese TTS Pro V8 Voice Rea
    Turkish TTS Pro V8 Voice Aysim
    And Special Thanks to others, they know who
    All Are in one single torrent-file, the size off the file are: 1.52GB
    Take what you want and delete the rest
    <<<Download>>>
    Please Remember To Seed Back To Keep Torrent Alive
    Have fun Guy's
    birger56 and benkoka like this.
    Only Torrent Uploads, Faster And Safely Downloads
    Android GPS software TomTom, Sygic, iGO, Navigon
    <<PUSH>>
    iGO R3 Maps around the world
    <<PUSH>>
    TomTom Iphone All Maps Around The World
    <<PUSH>>
  2. The Following 21 Users Say Thank You to ScorpioPirate For This Useful Post:
    Craigmill is offline Sergeant
    45
    Re: iGO Primo TTS PRO NUANCE V8 Edition
    Hi, I have iGO 9.6.7.235654 working with standard voices on my Samsung Tab 2 7" (android).
    I downloaded the Nuance TTS Pro Voices "English TTS Pro V8 Voices Iasonas, Medea" from this thread and followed the included installation instructions
    Installation
    Copy the file tts_nua_v5 to this path : Primo/
    Copy the vautov5.dll file to this path : Primo/
    Copy the voices to this path : Primo/content/voice
    Copy the lang.zip file to this path: Primo/content/lang
    copy the file United Kingdom_NQ_2011.Q3_111102 or you can add your file to this path: Primo/content/phoneme.
    Also in order to work the voice with Primo you should add this
    to your sys.txt (you can find sys.txt in this path: Primo/sys.txt)
    Open the sys.txt file with notepad and paste the following:
    [sound]
    csv_voice_enabled=1
    Unfortunately I cannot get it to work!
    I can see the tts pro voices in the voice selection but they do not play - the standard voices still play ok!
    In Sounds and Warnings the TTS Pro Label is greyed out!
    Should Nuance tts pro voices work with iGO 9.6.7.235654?
    Do I have enable tts pro somewhere else in the menus?
    Any assitance would be appreciated!!
    This are for windows ce.
    Sent from my GT-N7100
    45
    goodoane - Thanks for the info!
    Have you managed to get TTS working on your Note?
    Yes with Ivona tts for my native language and for English with svox or other tts apk.
    45
    Thanks - I will give it a try!!
    ScorpioPirate - maybe you should add a note at the start of the thread that Nuance is only for Windows CE!
    Juraj91 is offline Lance Corporal
    Feb 2013
    lucky to have CE thank you !
    Oct 2011
    The contents of both TTS versions (for Andriod and WinCE) are identical exept only one statement in the File info.ini:
    TTS-File Contents (left side for android, right side for WinCE):
    http://img43.imageshack.us/img43/7793/ttscontent.jpg
    info.ini differences (left side for android, right side for WinCE):
    http://img35.imageshack.us/img35/1056/ttsdifference.jpg
    you can simply edit the line and put the right statement into it:
    tts_engine="android"
    or
    tts_engine="nuance_v5"
    and you can use TTS files for both systems
  10. #9
    tussy is offline Corporal
    Jan 2011
    16
    hello ScorpioPirate ,
    Do you want like not torrent please , thank
  11. The Following User Says Thank You to tussy For This Useful Post:
  12. #10
    I have been using the English TTS Pro voices in the US with Q3 2012 maps. I thank ScorpioPirate and Zervdim for their hard work. However, all of the voices say strange things like:
    "drove" instead of "drive"
    "EB", "WB", "SB", "NB" instead of "East, West, South, or North Bound"
    "blvd" instead of "boulevard"
    "turn before the petrol station" instead of "turn before the gas station"
    "Turn right onto 20 Tee H street" instead of "Turn right onto twentieth street" or "Turn left onto 23 R D street" instead of "Turn left onto twenty-third street".
    I have successfully changed all these things, so I am posting English TTS Pro voices for USA with improved speech patterns acceptable in the USA. Here is the link:https://mega.co.nz/#!5dsXDDDZ!bZcjeW...ABdIL2GZSQFJKc
  13. The Following 2 Users Say Thank You to takawira For This Useful Post:
