  • 1 Post By Airion
Thread: igo TTS voices in iphone
    Feb 2012
    I have tryied everything but the "TTS PRO" option is still grayed out in igo.
    Can somebody help me to set it up ?
    Is something (setting, file) in IOS i should change ?
    Do I need a skin in order to get the TTS work ?
    iphone 4s with JB
    ios 5.0.1
    igo primo 9.6.9.216604
    3,132
    223
    Re: igo TTS voices in iphone
    You can't added any voices after you have installed into phone
    Before you install the software in iphone.
    Edit ipa using winrar and added the required voice & naunce details.
    gvp9000 likes this.
  3. The Following User Says Thank You to Airion For This Useful Post:
    Feb 2012
    Where can I find a working download link for those files and Greek lang ?
