Thread: Spanish Loquendo TTS v7 voices for Primo 2.4 WinCE
    optimvs's Avatar
    optimvs is offline Corporal
    Thumbs up Spanish Loquendo TTS v7 voices for Primo 2.4 WinCE
    Hello IGO friends, I introduce the core libraries for obtain Loquendo v7 Spanish castilian voices under IGO Primo 2.4. Already tested under GPS WinCE 6, 128MB RAM with Primo (european), Primo (chinese version), and Primo (european), all successfully.
    The ONE link will provide of base LTTS7 core engine with the Spanish-castilian support libraries into root folder, with x3 voices Carmen (thanks to zervdim) , Leonor and Jorge (thanks to moondefer) into loq_tts_7/ folder, plus LTTS7 full compatible Spanish male/female link files into content/voice/, and the Spanish language-dictionary file with added support for diMkaWA_P171 into content/lang/:
    <<< Primo24x3LTTS7Spanish.rar >>> (91MB)
    Password for RAR file: 314159
    NEW ADDED: x4 Voices Full Pack: Carmen, Juan, Jorge and Leonor with diMkaWA_P171 skin and spanish dictionary ready:
    <<< Primo24LTTS7Spanishx4Voices.rar >>> (131 MB)
    Very special thanks to Moondefer and Zervdim.
  2. The Following User Says Thank You to optimvs For This Useful Post:
    luizcarlosgps is offline Lance Corporal
    Sep 2011
    Re: Spanish Loquendo TTS v7 voices for Primo 2.4 WinCE
    Hi optimvs
    Thanks for the spanish voices.
    Unfortunatelly, the option Read out quick detour (Leer desvio rápido) isn't activated in your languages.
    To activate that feature, must be added some lines in the file dictionary.voice:
    QuickDetour~left=" girando a la izquierda, en "
    QuickDetour~right=" girando a la derecha, en "
    QuickDetour~sharp left=" haciendo una curva pronunciada a la izquierda, en "
    QuickDetour~sharp right=" haciendo una curva pronunciada a la derecha, en "
    QuickDetour~slight left=" haciendo una pequeña curva a la izquierda, en "
    QuickDetour~slight right=" haciendo una pequeña curva a la derecha, en "
    QuickDetour~straight=" seguiendo recto, en "
