Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Missing first part of first word TTS
    harrym1byt is offline Lance Corporal
    May 2011
    Primo 1.2 - Several of us, a group of car enthusiasts, have bought a Chinese double din satnav/ICE system. The satnav runs in WinCE 6 and silences the radio (or etc..) during a TTS announcement, it genearally works great - except....
    The first word or part of the word of the TTS announcement is missing or silent. 'Take the next left' sounds like '..ke the next left' - 'After 300 yards turn right' sounds like '..ter 300 yards turn right'.
    Is there a fix for this?
    No problems noted with Igo 8 or previous Primo versions.
    Matt174e is offline Private
    Re: Missing first part of first word TTS
    I'm in the same boat as you. Not only does it cut off the first part, but more annoyingly... it's silent for about 8 seconds after it says "Turn Left" or something. It's very irritating while listening to music.
    same situation, ideas? maybe sys.txt
    bazzle is offline Lieutenant
    Melb Oz
    347
    33
    Heres a 1st start, may do nothing.
    [sound]
    csv_voice_enabled=1
    [dynamiccompressor]
    compressor=1
    a0=56806
    thrs=24703
    ratio=8
    gain=10
    [3D]
    max_pois_on_horizont="2"
    max_pois="20"
    [3d_config]
    rotated_roadsigns=0
    roadsign_lines_per_screen="20"
    disable_roadsign_navigation_mode="1"
    [sound]
    csv_voice_enabled=1
    ding=0
    [warning]
    speedcam_maxdistance_from_road=50
    ;[debug]
    ;max_memory=35000000
    ;reserve_memory=1700000
    ;cache=600000
    OR try this in Debug, play around with the numbers??
    tts_min_ready_wav="1"
    tts_getaway_time="100"
    sound_q_length="200"
    Bazzle
    carl2222 is offline Lance Corporal
    Apr 2011
    did anybody find a solution to this problem
    HiroboFreak is offline Lance Corporal
    Sep 2011
    I have a 2din system fitted to my Sorento & I'm having the same problem.
    Has anybody found a definite solution yet?
    I would really like to use the TTS feature as it sounds very natural compared to the TTS system on my old stand-alone GPS unit.
    Sep 2011
    Is there someone who find a solution ?
    duffer is offline Captain
    Jun 2011
    665
    26
    Maybe? Try going into the voice's "info.ini" and play with tts_rate=. Change the value up and down and see if that helps.
    Sep 2011
    Quote Originally Posted by duffer View Post
    I am Also having the same issue of missing 1st part of announcement. Anybody got solve this ?
    Did this
    help?
    Eagerly waiting to fix this...
    959
    Post your complete sys.txt.
  1. 1st January 2012, 11:47
