9th September 2011, 07:45
#1
Need help from Gurus here on installing mapking
Hi,i'm new to gps system n need help on installing mapking software.i know 'nuts' n hoping any master here can help me how to go about with the installation.my in car dvd system using wince 5.0.i'm looking at installing spore n msia maps.i'm nt sure bout my device specs such as com,baud,resolution etc...by the way i'm using Motevo Gtv-x5 unit. See link for info-http://www.onlinecarstereo.com/CarAudio/p_20496_Motevo_GTV-X5.aspx
Hope someone here can enlighten me.thnks a million
9th September 2011, 07:59
#2
Re: Need help from Gurus here on installing mapking
Chhose another software. Mapking Landmark version is dead without map updates. map backdated - 05/2010.
Only Official Mapking version Hong Kong base has map updates.
use Papago version - latest maps 110823
As for your unit - no idea
You have to find out the resolution correctly.
The working com & baud rates for GPS signals.
Find it in the Papago GPS software threads.
Com post scan.
Without these details no can help you at all.
9th September 2011, 08:53
#3
Thnks for the fast reply,i will try to check the com n baud rates n will let u know the details
11th September 2011, 13:51
#4
I've dwload the program frm the Papago section to check for com n baud but my in car dash unit cant run the program..
