Hoho, also here waiting for the solution.
If you are in singapore, you can look for this guy for help: Max @ 84149540.
I'm having problem installing Mapking on my china made 7" Car GPS unit also...currently it is running iGO 8.
Can tell me which mapking version u using? Have you solve your resolution problem already?
Anyone can give me link for Mapking 320x240 with Com 2, Speed 9600..
Thanks.
anybody can share their mapking
com : 1
baud : 4800
Try this Mapking OBU R12 Build 0603
Please refer to new thread I just created ( Mapking OBU R12 Build 0603, May24, 2011) for further information.
