amirabe iGO8 is on the sdcard?
i need some help, i hope it is the right place.
i have mio moov s501 with navman.
in order to install igo i changed the file : "PATHS"
so instad of running miomap at it runs igo at startup.
the problem is now i cant access the flash memory of the device. it wont sync with the pc.
anyone have any ideas?
Any updated links available please?
look HERE![]()
Is there a way to remove unwanted icons from the first screen at all please?
IYou should edit file MioAutoRun\Unlock\Skin\Pages\write_navi.
This section :
FOR i = 1 to 12
Insteed 12 put you're maximum number of icon .
After you run once SetPath your interface will change.
The position on the screen you can change by modify in the same file section :
X[1] = 18
X[2] = 95
X[3] = 172
X[4] = 249
X[5] = 326
X[6] = 403
X[7] = 18
X[8] = 95
X[9] = 172
X[10] = 249
X[11] = 326
X[12] = 403
Y[1] = 60
Y[2] = 60
Y[3] = 60
Y[4] = 60
Y[5] = 60
Y[6] = 60
Y[7] = 145
Y[8] = 145
Y[9] = 145
Y[10] = 145
Y[11] = 145
Y[12] = 145
i have problems with unlook my Spirit 687!
The smartSt_Ce files a copied and the Folder MioAuto Run is on a correkt place!
The Mio started and then:
Applications Error
"Application MortScript.exe
encounted a serious error
and must shut down."
anyone knows whats the problem?
any solutions maybe?
aladin02
this is my folder.
And the fault Meesage
Applications Error
and must shut down.
aladin
