Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 72
Like Tree4Likes
Thread: SD & Flash Unlock for Mio Spirit with SPIRIT / NAVMAN
  1. #41
    orion.gre11 is offline Corporal
    Dec 2011
    22
    Re: SD & Flash Unlock for Mio Spirit with SPIRIT / NAVMAN
    I am O.K. with iGO I dont need PRIMO wriht now.But I wonder if I can make some shortcuts when I get some other navigators.
    Thanks!
  2. #42
    gyany is offline Second Lieutenant
    Mar 2012
    A, A
    340
    yes.It can run any program.Renaming the program and executable in iGO8.You can make other shortcuts..is a little more difficult.Can I send a multi unlock software
  3. #43
    Dec 2011
    22
    Please send it I will lke to try.
  4. #44
    spriggan's Avatar
    spriggan is offline Major
    772
    21
    Quote Originally Posted by orion.gre11 View Post
    look at your PM for igo8
  5. The Following User Says Thank You to spriggan For This Useful Post:
  6. #45
    Dec 2011
    22
    Thanks.Do you have anything about creating shorcuts or a desktop with more shortcuts??
  7. #46
    Mar 2012
    A, A
    340
    orion.gre11 Unlock.zip 1)Connect the device to your computer and delete folder Unlock. 2)Unzip and copy instead of this folder Unlock.Hardreset...Ciao
  8. The Following User Says Thank You to gyany For This Useful Post:
  9. #47
    funkoligy is offline Corporal
    Nov 2011
    Hi im looking for fresh link to Visual gps unlock for mio/navman 475 sat man. please if anyone has this unlock I would be glad to get it. im missing the visual.ins file. Thanks
  10. #48
    Dec 2011
    22
    funkoligy: Try that one
    www.lanik.org
  11. #49
    duffer is offline Lieutenant
    Jun 2011
    436
    www.lanik.org
    Good. But I hope you realize that Primo is not part of the programs.
  12. #50
    Dec 2011
    22
    Rename PRIMO at something else that you dont use.
