Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 72
Like Tree4Likes
Thread: SD & Flash Unlock for Mio Spirit with SPIRIT / NAVMAN
  1. #51
    orion.gre11 is offline Corporal
    Dec 2011
    22
    Re: SD & Flash Unlock for Mio Spirit with SPIRIT / NAVMAN
    duffer::I have look again and I think that PRIMO is in.
  2. #52
    duffer is offline Lieutenant
    Jun 2011
    436
    Quote Originally Posted by orion.gre11 View Post
    You are correct. I must have missed it. I only saw Igo8 and Amigo. Sorry about that.
  3. #53
    Dec 2011
    22
    With what navigator you use the Visual gps?????
  4. #54
    Dec 2011
    22
    Dear gyany I have try to the unlock you send me to run a Miomap from the Primo short cut, after I rename the Miomap folder and miomap.exe to Primo and primo.exe.The program starts with the miomap screen and then nothing.Must I change something else, maybe because the original program in flash is miomap too?????
  5. #55
    gyany is offline Second Lieutenant
    Mar 2012
    A, A
    340
    orion.gre11 1)Connect the device to your computer and delete folder Unlock. 2)Unzip and copy instead of this folder Unlock.Hardreset...Ciao >>>>This unlock has the option SetPath http://ge.tt/7pp7CsW/v/0
  6. The Following User Says Thank You to gyany For This Useful Post:
  7. #56
    Dec 2011
    22
    With that unlock everything are frozen at mio icon!!!!!
  8. #57
    Mar 2012
    A, A
    340
    You did something wrong..If you can work directly on Team Viewer??
  9. #58
    Dec 2011
    22
    I dond have.But I delete the unlock file and I replaced with the new one.Never mind I"ll keep the old unlock file.Anyway thank you for your time.
  10. #59
    Romania
    Thumbs up Re: SD & Flash Unlock for Mio Spirit with SPIRIT / NAVMAN
    Multumesc Irinuca.
    Unlockul mi-a fost de mare ajutor pentru S 555.
    Sa traiesti, sa fi sanatos, tu si familia ta.
  11. The Following User Says Thank You to afy06 For This Useful Post:
  12. #60
    Jun 2011
    436
    Quote Originally Posted by afy06 View Post
    Multumesc Irinuca.
    Must be a secret, don't you think?
