HI all,
Just bought one Mio model N255 (M400-vompatible) with start screen mio and later show connection on display .
When i attach to PC i receive new device like HDD with just 3 files.
Obviously previous owner have been unlocked and deleted all needed files for starting.
Read a lot of pages, but cannot find original deleted files anywhere.
Even follow procedure to install new WinCE and received blue start-up screen, but can`t continue because this device have not SDcard slot.
On Miomap desktop - . device is not connected.
so my question is how to revive this navigation?
All you need is this content of original internal memory:
https://rapidshare.com/files/4118067...ackup_orig.rar
Unrar, copy to internal
hi all
i reply to this topic because i need to update the maps of my Mio Moov M400 N255 (actually have europa 23 maps) and I'd like to put on it the Italian & Western Europe Map.
Is it possibile? there's a simply guide on how to do it?
Thanks in advance
K-Line How much free memory you have in the device? I can help you put into the machine and iGO8,according to free memory.If you can replace the original with iGO8 software with full Europe maps.
thanks for your reply, gyany!
if you mean the free space of the device, when i connect to my laptop it says that there's 546 MB left on the 1,8GB that it have.
if you mean the ram of the navigator, i tried to look for it in the menu but I didn't find anything that show me this value
thanks
K-Line https://rapidshare.com/files/1718660114/minishell.zip 1)Unzip in the computer 2)Connect the device to your computer and in Program Files \ Navman \ SmartST_CE \, rename SmartST_CE.exe in SmartST_CE1 3)Copy directly into the device Minishell and Media 4)Copy to Program Files \ Navman \ SmartST_CE, files in the folder For SmartST_CE .... here is iGO8 >>>https://rapidshare.com/files/2823887180/iGO8.zip AND HERE MAPS >>>http://mihaelart.ro/gps/ -------IGO8 copy directly into the device(WARNING TO MEMORY AVAILABLE) ...maps are put in iGO8 \ Content \ Maps.
Thanks again, gyany!
I read your instructions and are very clear until the map website
which one of the files do I have to download to get the Italy&Western Europe map on my navigator?
If are the Mireo/Miomap them are bigger than my navigator memory... I saw that the file are about 2GB while my navigator got "only" 1,8GB (if I delete everything from it)
thanks again
navteq ---NQ 2011Q4 fbl >>>>>You can remove unnecessary maps
